Author Topic: Determining plate-mount stabilizer compatibilty  (Read 5978 times)
Offline zutroy
« on: Tue, 12 September 2017, 18:12:38 »
Is there any easy way to identify whether a plate is compatible with Cherry-style plate-mount stabilizers? A certain style of cut-out maybe? Or a min/max height for the cut-out?
I busted the spacebar PCB-mount stabilizer on one of my boards (inserts on a new spacebar cap were really tight, and when I tried to remove the key, the stab inserts came right out...from there I tried to tinker everything back together, but it didn't work too well) and was thinking about replacing it with a plate-mount stab, so that in case something like this happens again, I won't have to desolder several switches to replace the stab. The board has a bent steel two-in-one case/plate, like so:
Offline Tactile
Re: Determining plate-mount stabilizer compatibilty
« Reply #1 on: Tue, 12 September 2017, 18:50:07 »
To mount the spacebar stabilizer, Cherry plate mount stabs require this slot in order to insert the wire.
178195-0
REΛLFORCE
Offline zutroy
« Reply #2 on: Tue, 12 September 2017, 18:53:54 »
Perfect. That answers my question. Guess it's PCB-mount for this one.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #3 on: Tue, 12 September 2017, 19:46:19 »
For what its worth, I am of the camp that prefers the PCB mount stabs along with a few minor tweaks.
-Dana
