Author Topic: are newer zealios better?  (Read 3242 times)
Offline weeaboocookie
« on: Wed, 13 September 2017, 20:02:13 »
hey guy i tend to see people want zealios r4 or newer. Is there any problems with older ones or are the new ones are just better. thanks just asking because im going to get some for pok3r
Offline yuppie
Re: are newer zealios better?
« Reply #1 on: Wed, 13 September 2017, 20:47:47 »
newest zealio best zealio buy new, accept no less.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline klennkellon
  • I like bottoming out
« Reply #2 on: Wed, 13 September 2017, 21:00:03 »
there hasn't been any major differences since r 4.5 imo
Offline nugglets
« Reply #3 on: Wed, 13 September 2017, 21:46:07 »
R4.5 is exactly the same as R4. I don't think there have been any other changes since then, either. Maybe some tweaks to the stem colors? I can't remember exactly when that happened.
As for the older versions, honestly they were still great. R4 the stems changed to reduce wobble but, IMO, the wobble in previous rounds wasn't more noticeable in actual usage than any other switch.
Offline Rodde
« Reply #4 on: Sun, 17 September 2017, 21:17:06 »
Is there an easy way of telling what generation of Zealio it is?
Offline merlin64
    • MechMerlin
« Reply #5 on: Tue, 19 September 2017, 13:56:45 »
I believe R6 is when they started changing the color of the stem to denote which spring weight a Zealio originally came in.
By color I mean...light purple to dark purple.
Offline xondat
  • i'm not a star
« Reply #6 on: Tue, 19 September 2017, 14:17:01 »
It was R2.
  • R1 is all the same color.
  • R2 changed pigmentation (light to dark, 62 to 78)
  • R3 had no changes
  • R4 had stem wobble reduced
  • R4.5 had no changes
  • R5 had no changes
  • R6 had translucent bottoms changed color (white is PCB mount, cream is plate)
  • R7 has no changes
I believe this is accurate but I'll go and check it up.
In short, unless you're getting a great deal on R4 or lower, or a good deal on R4.5 onwards, just buy new.
