Author Topic: Warning: Cheap replacement keys not a great find  (Read 3350 times)
Offline E TwentyNine
    • Some of My Keyboards
« on: Wed, 13 September 2017, 22:28:28 »
Before someone jumps on this: http://www.ebay.com/itm/IBM-Clicky-M-Computer-Keyboard-Replacement-Keys-used-complete-set-/272845152564 which is a decent price for a replacement set of keys, note that they are for a rubber dome M and will not work in a buckling spring M.
Offline ander
  • I type, therefore I am
Re: Warning: Cheap replacement keys not a great find
« Reply #1 on: Thu, 14 September 2017, 03:00:17 »
Sharp eye, man! Yep, that middle tab's unmistakable.
Did you point this out to the seller? I see the description is now clear that they're for RD Model M's only.
« Reply #2 on: Thu, 14 September 2017, 08:27:56 »
Yes.  He updated the listing surprisingly quickly after I sent him a note.
Offline 0100010
  • Not Sure
« Reply #3 on: Thu, 14 September 2017, 09:00:18 »
It does have a spacebar spring though.
