Author Topic: using AMJ40 USB1 port  (Read 3050 times)
Offline pabile
    • pabile online
« on: Fri, 15 September 2017, 00:47:20 »
So my AMJ40 acted up after a little over a month of daily use. I am getting "Unrecognized USB device" error on windows machines. I did some poking and it seemed something is wrong with its USB port.
What I wish to know now is check with you guys if anyone tried to use USB1 of the AMJ40 PCB? If so, are these the correct pin out?
1 Volt
2 D-
3 D+
4 ID
5 Grnd
Offline pabile
    • pabile online
Re: using AMJ40 USB1 port
« Reply #1 on: Fri, 15 September 2017, 02:18:33 »
based on this information, i think i got my pin out right...
...it should be the other way around.
Offline TalkingTree
    • My projects
« Reply #2 on: Fri, 15 September 2017, 03:40:18 »
See that header between C2 and R1/R2? That's likely to be a USB breakout. Flip the board over to see if it's labelled.
Know that the Unrecognized USB device error could be a USB 3.0 issue. Try and plug your board into a USB 2.0 port or through a USB 2.0 hub.
And mr. pabile is right about the pinout.
« Last Edit: Fri, 15 September 2017, 03:42:19 by TalkingTree »
Offline pabile
    • pabile online
« Reply #3 on: Fri, 15 September 2017, 03:52:26 »
oh! cool! did not noticed that... bad thing now is that i could not see the other side due to the soldered switches and plate. will try to ask the seller if i can have photos.
I only have USB 2.0 at work and home... :(
thanks for the confirmation :)
Offline TalkingTree
    • My projects
« Reply #4 on: Fri, 15 September 2017, 06:16:27 »
No need. The hole with the square pad (the rightmost) is likely to be the VCC, so you infer the rest from that. For extra safety you can use a multimeter to check continuity.
Offline pabile
    • pabile online
« Reply #5 on: Fri, 15 September 2017, 22:07:01 »
thanks, Talkingtree
using multimeter confirms the breakout is alive! i was able to use this breakout for i while...
178447-0
... until i had trouble removing the existing usb port then for some reason, i was able to re-enforce solder joints and revived the whole board. typing on it right now   :D
