Author Topic: [GB]KBDfans 5° 60% aluminum case ---All orders are shipped  (Read 115321 times)
Offline graefeln
Re: [GB]KBDfans 5° 60% aluminum case
« Reply #100 on: Thu, 23 November 2017, 02:26:02 »
Just got an email that my [orange] case shipped!
Offline skidude9678
« Reply #101 on: Thu, 23 November 2017, 08:32:13 »
I also received shipment notification for my cyan one!
Offline SantiGo
« Reply #102 on: Thu, 23 November 2017, 14:02:37 »
me need this /// can i Buy ?
Offline Lisinge
« Reply #103 on: Thu, 23 November 2017, 18:00:42 »
This was a groip buy which has already ended. You will have to wait for round 2
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #104 on: Thu, 23 November 2017, 19:09:17 »
I emailed KBDfans about this during the group buy — the Diamond Cut case will be available as a stock keeping unit on the KBDfans store, albeit at a more expensive price.
Offline Rumblehotep
« Reply #105 on: Thu, 23 November 2017, 19:15:07 »
Given there was a question about the purple finish and a vote I assume it will go out last  :-X
Offline Lisinge
« Reply #106 on: Thu, 23 November 2017, 19:47:10 »
From what they said three days ago on reddit it actually looks like they are going to run another round of GB instead https://www.reddit.com/r/MechanicalKeyboards/comments/7e5alo/5_degrees_case_purplethe_color_is_uncertain/dq2p4kn/?context=3&st=jad8qalk&sh=f6ad3289
They had 529 cases ordered and they made 660 cases but some are probably extras for replacement etc
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #107 on: Thu, 23 November 2017, 20:55:33 »
I guess they changed their mind then. Oh well.
Offline Sputnik
« Reply #108 on: Fri, 24 November 2017, 13:48:52 »
Mine arrived today. Looks nice.
The only keyboard I have at home is a Pok3r and the plate seemed to be a little too wide for it to fit, which is a bit worrying.
Will bring my banana split home from work tomorrow and see how that goes.
Did you try with the Banana? I'm waiting for both (case and Banana split R2), so reeeally interested....
Offline dodgeyhack
« Reply #109 on: Fri, 24 November 2017, 19:07:14 »
Not yet sadly. I was off sick Friday so didn't bring the Banana home. I will try Monday night. That reminds me - I need to go buy a file in case I have to remove any of the extra mount bits.
Offline Rumblehotep
« Reply #110 on: Fri, 24 November 2017, 20:58:54 »
Oh that's great, I really wish I had bought an orange case.
Offline HotRoderX
« Reply #111 on: Sat, 25 November 2017, 03:11:04 »
what i can tell when he does a group buy he orders some extra's in basic colors.. Silver/black/ and then like red are something... to order from his shop. I betting its the same thing with this.. most likely 50 of silver 50 of black then replacement cases encase there issue.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #112 on: Sat, 25 November 2017, 07:07:24 »
Some pics are up of the black, cyan and orange cases over at KBDfans : https://kbdfans.myshopify.com/blogs/news/5-case-black
Offline Lisinge
« Reply #113 on: Sat, 25 November 2017, 11:18:30 »
My cases just shipped. Ordered one grey and one purple
Offline KaosJ
« Reply #114 on: Sat, 25 November 2017, 11:31:03 »
Wait, did the purple shipped  :eek:
Offline Lisinge
« Reply #115 on: Sat, 25 November 2017, 12:36:34 »
Looks like it, like i said i ordered both grey and purple and they said they would ship them both at the same time :p
I changed colors on my order though so i hope it ends up correctly :D
Offline AuthenticDanger
« Reply #116 on: Sat, 25 November 2017, 13:36:39 »
Anyone with Red one get a shipping email? I'm so eager to get this case!
F Keys belong on the left.
Offline Atredl
« Reply #117 on: Sat, 25 November 2017, 17:12:27 »
By mount bits do you mean the pcb standoffs in the case? wouldn't it be easier and much less damaging to just put some tape or other thin insulating material on the unused standoffs?
Offline Rumblehotep
« Reply #118 on: Sat, 25 November 2017, 17:15:47 »
Just got a notification for my Dark Purple, nothing for Dark Blue yet
Offline Atredl
« Reply #119 on: Sat, 25 November 2017, 17:43:58 »
The poker plate is slightly larger than normal I think, at least my RGB it is. I totally scratched the **** out of a sentraq case trying to use it on my RGB Pok3r and the plate was just a tiny bit too wide. But that was AFTER i had been using the case with my Zeal60 and Mekanisk plate. For me tight tolerances is a positive not a negative :D.
You know, it's kind of ironic that the Pok3r plate doesn't fit as easily as aftermarket plates. Especially since the Poker is what all the "standardized" 60% dimensions came from. :thinking:
Offline Lisinge
« Reply #120 on: Sat, 25 November 2017, 18:38:55 »
Did anyone get any tracking? Mine just says that it shipped but no tracking available
Offline pixelpusher
« Reply #121 on: Sat, 25 November 2017, 18:50:31 »
I see your point, but it does make sense bc the poker plates are indeed wider than all of the universal 60%plates out there.
Offline Atredl
« Reply #122 on: Sat, 25 November 2017, 20:22:03 »
Sure but I'm not saying it doesn't make sense. Just looking back and thinking about how the market changes, even for the trendsetter like the Poker.  :)
Offline kekstee
« Reply #123 on: Sun, 26 November 2017, 01:26:35 »
It's where we got the ****ed up mounting points for tray cases. At least here's another one in the lower left which should fix the usual issues. Plates didn't arrive in Pokers until much later, namely the Poker 2. Plus they were low profile.
Nice, first picture of cyan I get to see :D
« Last Edit: Sun, 26 November 2017, 01:28:18 by kekstee »
Offline mogo
« Reply #124 on: Sun, 26 November 2017, 02:41:00 »
The black finish is alarmingly gorgeous and a little bit of me regrets not picking black. But most of me is just antsy because my case is stuck in customs at the moment.  :-X
Offline Lisinge
« Reply #125 on: Sun, 26 November 2017, 04:15:30 »
Pictures of dark purple and dark blue are up on the gb update page https://kbdfans.myshopify.com/blogs/updates/5-case-update
Offline dodgeyhack
« Reply #126 on: Sun, 26 November 2017, 04:29:56 »
Yeah standoff would be the term I was looking for. My concern is that there may be diodes or some other component in the way.
There was some discussion of that in the banana split GB thread
Offline smithyithy
  • a l p s
« Reply #127 on: Sun, 26 November 2017, 05:13:55 »
From those new photos I'm not sure which of the poll colours they've gone with for the purple..
KBD75; Alps64 trio; some other stuff
Offline Lisinge
« Reply #128 on: Sun, 26 November 2017, 05:26:44 »
Same here. It almost looks more lavender than dark purple. I hope it's just the lightning
Offline KaosJ
« Reply #129 on: Sun, 26 November 2017, 06:18:37 »
The right one, dark purple
Offline smithyithy
  • a l p s
« Reply #130 on: Sun, 26 November 2017, 07:28:39 »
 :thumb:
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #131 on: Sun, 26 November 2017, 09:11:29 »
Those pictures look more like purple A than purple B :(
Offline Vigrith
« Reply #132 on: Sun, 26 November 2017, 10:05:51 »
Agreed. Also uh oh, I've never had KBDfans' stuff get stuck in customs, hopefully this doesn't happen this time round either.
Offline KaosJ
« Reply #133 on: Sun, 26 November 2017, 10:16:38 »
I really hope these are just strong lights making it a violet color
Offline Denisgsv
« Reply #134 on: Sun, 26 November 2017, 13:16:28 »
its for sale now in their shop who is fast can grab one
Offline pixelpusher
« Reply #135 on: Sun, 26 November 2017, 22:04:32 »
Man oh man, that orange looks so nice.  I should have bought orange.  damnit.
Offline Rumblehotep
« Reply #136 on: Sun, 26 November 2017, 22:12:18 »
Worried about that purple. hoping the photo is using a super bright light
Offline dodgeyhack
« Reply #137 on: Mon, 27 November 2017, 04:32:39 »
For those wondering about the Banana Split...
TL;DR; It fits nicely and looks great!
183044-0
The little bits of post it note (3) show where the extra standoffs make contact with the pcb.
In all cases, there's just enough space around the SMDs, so no filing required.
183038-1
The side standoffs don't align with the screw holes. But the inner four line up perfectly so not a big issue.
183040-2183042-3
« Last Edit: Mon, 27 November 2017, 04:38:05 by dodgeyhack »
Offline Lisinge
« Reply #138 on: Mon, 27 November 2017, 05:49:14 »
B confirmed. B is for best purple
Offline KaosJ
« Reply #139 on: Mon, 27 November 2017, 07:36:07 »
Damn that looks very nice, so hyped to get my Dark purple ;)
I saw your post on reddit for the bananasplit not fitting, does the no screw on the edges affect anything? (i never had that problem)
« Last Edit: Mon, 27 November 2017, 07:38:19 by KaosJ »
Offline KaosJ
« Reply #140 on: Mon, 27 November 2017, 07:37:05 »
Yeah they just said the same to me.  Perfect news since B was miles better
Offline Lisinge
« Reply #141 on: Mon, 27 November 2017, 07:45:25 »
I'm so excited it really looked amazing. I've got all my purples ready for it. Really wanted the white modifiers for my jtk pow set but i have been looking for she's without any luck
Offline KaosJ
« Reply #142 on: Mon, 27 November 2017, 07:55:31 »
Seems like we are doing the same thing!
I'm planning:
  • Purple case
  • DZ60, eventually with split spacebar
  • Zealios or Zandas
  • JTK PoW
Purple dream   ;D
Offline Lisinge
« Reply #143 on: Mon, 27 November 2017, 08:06:05 »
I'm planning:
  • Purple case
  • Zealios or Zandas
  • JTK PoW
Purple dream   ;D
Haha seems we do ;D i got the R8 Zealios coming in and im puttibg my zeal60 in there for ultimate purpleness.
I have to admit i got the same purple cable from mechcables after seeing your post on reddit...
Offline Applet
« Reply #144 on: Mon, 27 November 2017, 09:35:48 »
Potato-pic of mine.
Currently a alps64 with clicky modded oranges in it :)
Offline Vigrith
« Reply #145 on: Mon, 27 November 2017, 10:27:18 »
Potato-pic of mine.
Beautiful choice! Such a fantastic alternative to the super expensive alps cases people have been selling of late.
PS: if you don't mind my asking, did your shipment have to go through customs or is KBDfans still using their regular proxy for European orders?
Offline Applet
« Reply #146 on: Mon, 27 November 2017, 10:37:49 »
Potato-pic of mine.
Thanks! :) The shipent was with DHL via fedex, not sure what their regular proxy is tho. I have not yet paid any customs fees, but sometimes these get invoiced later. Declared value was something like $18, so it should not be that bad :)
Offline KaosJ
« Reply #147 on: Mon, 27 November 2017, 10:43:44 »
I'm planning:
  • Purple case
  • Zealios or Zandas
  • JTK PoW
Purple dream   ;D
rofl bro-hug.  Oh yeah that 90n1ne cable is awesome. Hope you have the purple deskmat too :D
Offline KaosJ
« Reply #148 on: Mon, 27 November 2017, 10:45:52 »
I would like to know too, a while ago i asked KBDFans and they said they will use the proxy (uk proxy if i'm not wrong).
Offline Vigrith
« Reply #149 on: Mon, 27 November 2017, 11:00:20 »
That's plenty enough for me to go off of, answers my question perfectly - thanks very much for taking the time to respond!
