Author Topic: [GB]KBDfans 5° 60% aluminum case ---All orders are shipped  (Read 115322 times)
Offline AuDiTH
Re: [GB]KBDfans 5° 60% aluminum case
« Reply #200 on: Tue, 05 December 2017, 13:37:29 »
Anyone tried zeal60 yet?
I have Zeal60 (R1) in my purple case now and the board fits pretty well, but the USB port position doesn't line up with center of the hole which causes a bit trouble when plugging in cable.
SSK | AEK64 | TX-CP | HHKB | Acrylic Pearl | Duck Orion V3 | LZ MP | Kyuu Sakura
Offline AuDiTH
« Reply #201 on: Tue, 05 December 2017, 13:41:56 »
Also, what about the FaceW?  They've been delayed for like 1/2 a year now at mechanicalkeyboards.com, but if they ever do come into stock, that could be a good option.
There are some available in Sprit's eBay shop: https://www.ebay.com/itm/FaceW-60-PCB-SPRiT-Designs-LED-Underglow-Macro-Cherry-Keyboard-Vintage-GH60/222709667335?hash=item33da87d607:g:ZZ8AAOSw-0xYYVaI
Offline mogo
« Reply #202 on: Tue, 05 December 2017, 13:56:00 »
repost for new page, hope that's okay.
  • Pok3r pcb doesn't fit if it has USB-C. (according to KBDfans)
  • Anne Pro will only align on two screw holes. (according to commenter Ti)
  • GH60 fits, but has a problem with one of the posts, apparently? (Frustrating, since it was one explicitly stated as being compatible. Is it something that can be solved by shaving off one post or what?)
  • DZ60 with MiniUSB should work (but then again, we've seen that just because KBD advertises compatibility doesn't mean it's going to be perfect).
  • Banana Split fits with four internal posts matching up, but three other posts will touch the PCB in other places and the outermost edge holes don't line up enough.(Thank you dodgeyhack)
  • Alps64 fits. (Thank you Applet and tron)
  • NERD Gon60 fits. (Thank you TalkingTree)
  • Zeal60 fits (Thank you AuDiTH)
Offline macken
« Reply #203 on: Tue, 05 December 2017, 14:02:25 »
Hi,
has anybody got a picture of how the dark purple case looks like in real life?
Only one I have seen is the A/B picture from the group buy.
Offline Atredl
« Reply #204 on: Tue, 05 December 2017, 14:06:21 »
Once my case comes in I can test if a Winkeyless b.Face fits.
I've always been unsure, are the FaceW and the b.Face essentially the same pcb or are there differences?
Offline Ponkan
« Reply #205 on: Tue, 05 December 2017, 14:25:43 »
My brother got an allen wrench and some screws with his purple case. I didn't get those in my black case. What are those screws for?
Offline dr_derivative
  • Not a real doctor
    • OC Lab Discord
« Reply #206 on: Tue, 05 December 2017, 14:29:50 »
Those screws are for fitting the included blockers
GH/Reddit/DT/Discord: dr_derivative | IG: dr_derivative_mk | Discord server: OC Lab
Offline Ponkan
« Reply #207 on: Tue, 05 December 2017, 14:38:49 »
Do I ask them for those to ship them to me or do I have to find those screws somewhere else?
  • Not a real doctor
    • OC Lab Discord
« Reply #208 on: Tue, 05 December 2017, 14:43:41 »
You should try asking them, they're usually pretty good at fixing things like this. Just make sure to explain the situation in simple terms, since they're not native English speakers.
Offline AuDiTH
« Reply #209 on: Tue, 05 December 2017, 16:14:07 »
Hi,
Here's some quick pics of mine with GMK hyperfuse
183587-0
183589-1
« Last Edit: Tue, 05 December 2017, 17:06:52 by AuDiTH »
Offline Atredl
« Reply #210 on: Tue, 05 December 2017, 16:22:38 »
Hi,
Is it just me or does that purple look a lot less saturated than either the A or B option?
Poll picture:
Update post on KBDfans:
« Last Edit: Tue, 05 December 2017, 16:35:18 by Atredl »
Offline AuDiTH
« Reply #211 on: Tue, 05 December 2017, 17:05:44 »
Hi,
Poll picture:
The lighting in these pics was pretty bad so I had to turn up brightness a bit, sorry about that. But seeing it person I would say B option is pretty accurate.
Offline KaosJ
« Reply #212 on: Tue, 05 December 2017, 17:17:00 »
Anyone tried the iGK61 pcb from the last GB (hotswappable and Type-C)
Offline pixelpusher
« Reply #213 on: Tue, 05 December 2017, 18:12:18 »
I haven’t tried mine yet bc I still don’t have my case but I’ll try as soon as I get it
It looks like only a few of the holes are going to line up, though. And those hot swap sockets are more than likely to cause clearance issues.
Offline macken
« Reply #214 on: Tue, 05 December 2017, 19:18:03 »
Hi,
Poll picture:
So going with dark purple would be a good match with Laser GMK? OR better with black?
Offline AuDiTH
« Reply #215 on: Tue, 05 December 2017, 19:54:02 »
Hi,
Poll picture:
The colors aren't exact matches but dark purple would look nicer than black imo
Offline macken
« Reply #216 on: Tue, 05 December 2017, 20:19:17 »
Is it Fjell dark purple? Saw the dark was up to order on their site now.
Offline amnesia0287
  • Formerly Amnesia
« Reply #217 on: Tue, 05 December 2017, 20:51:49 »
I'll have purple klippe and dark purple 5deg in a few days. I'll take side by sides :D.
Offline lunr
« Reply #218 on: Tue, 05 December 2017, 21:59:21 »
Don't think the purple Fjell is the same as the Klippe. I have the purple Klippe and it's more darkish magenta.
« Reply #219 on: Tue, 05 December 2017, 22:10:48 »
klippe r1 and r2 are different purples
Offline Ponkan
« Reply #220 on: Tue, 05 December 2017, 23:23:44 »
Here's my fair share of pictures! It looks great I thought.
Offline KaosJ
« Reply #221 on: Wed, 06 December 2017, 03:55:59 »
That's a good purple  :thumb:
Doesn't really look like the dark purple B of the vote-pool but seems fine to me.
« Last Edit: Wed, 06 December 2017, 04:03:22 by KaosJ »
Offline Lisinge
« Reply #222 on: Wed, 06 December 2017, 05:44:45 »
The purple looks so good. At least it's purple and not magenta
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #223 on: Wed, 06 December 2017, 06:20:13 »
Any typing sounds?  :)
Offline pixelpusher
« Reply #224 on: Wed, 06 December 2017, 07:29:50 »
Looks great!
Offline macken
« Reply #225 on: Wed, 06 December 2017, 16:23:27 »
Nice, looking forward to that.
Offline AuthenticDanger
« Reply #226 on: Wed, 06 December 2017, 16:33:48 »
Red cases are starting to ship!
F Keys belong on the left.
Offline KaosJ
« Reply #227 on: Wed, 06 December 2017, 16:35:19 »
Interested in this comparison.
Also if anyone has a FJELL dark purple and want to compare them as well
Offline skidude9678
« Reply #228 on: Wed, 06 December 2017, 18:19:45 »
Got my cyan one in today. Fits my Alps64 perfectly.
Offline Rumblehotep
« Reply #229 on: Wed, 06 December 2017, 20:55:53 »
Perfect!
Offline smithyithy
  • a l p s
« Reply #230 on: Thu, 07 December 2017, 03:37:47 »
Awesome! Mine's sat in Customs   :confused:
KBD75; Alps64 trio; some other stuff
Offline HotRoderX
« Reply #231 on: Thu, 07 December 2017, 04:11:14 »
mine is also sitting in customs once again =/ Jcex shipping is kinda crap. Only reason I am not directly complaining is because free shipping was free. I have had packages thought EMS clear customs faster then JCEX.. I don't understand what the deal is. Typically Jcex = 3-5 day's in customs. Where EMS is 1-2 and Fedex/DHL is 0..
Offline macken
« Reply #232 on: Thu, 07 December 2017, 16:17:57 »
Seems like all the colors are available for preorder over at kbdfans site now.
Had plans to use the Laser set for a bigger board, but this case seems almost too good for the price. And lots of options for layouts when combining it with an DZ60 board.
Offline SantiGo
« Reply #233 on: Thu, 07 December 2017, 18:27:13 »
Lol realy? I buying r2 banansplit. And isee type c usb not good with this case??
Offline mogo
« Reply #234 on: Thu, 07 December 2017, 21:14:02 »
  • KBT Pure PCB fits perfectly on all six holes.
(updating because I just put my Pure PCB in out of impatience. Love it.)
Offline eksuen
  • Ambassador of explosions.
« Reply #235 on: Fri, 08 December 2017, 00:17:00 »
The DZ60 lines up at all the standard mounting points. I haven't secured it yet because I still need to solder everything, but I don't foresee any issues.
Offline HotRoderX
« Reply #236 on: Fri, 08 December 2017, 00:21:17 »
I will try to report back if a KBParadise will fit it. I have one laying around that doesn't have a case. I have personally found that the KBParadise doesn't always fit things that a pok3r will.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #237 on: Fri, 08 December 2017, 00:28:13 »
That is stunning. Like a big brother to my minivan.  :thumb:
-Dana
Offline SantiGo
« Reply #238 on: Fri, 08 December 2017, 01:24:21 »
All pcb with type C usb not good??? Or only po3ker ??
Offline Atredl
« Reply #239 on: Fri, 08 December 2017, 02:11:44 »
All pcb with type C usb not good Or only po3ker ??
The type-c port is a bit bigger than mini usb. Up until now most 60% cases were made with mini usb in mind, so they don’t have a hole that’s big enough for type-c. Not sure if that’s the case here but it’s likely.
Offline madn3ss795
« Reply #240 on: Fri, 08 December 2017, 07:50:41 »
This case fits GK64 PCB which uses type-c so there shouldn't be any problems. Album from reddit https://imgur.com/a/7wvJZ
Type C Poker is the "New Poker 2" which doesn't fit any custom cases anyway as its mounting points are different from previous Pokers.
« Last Edit: Fri, 08 December 2017, 07:52:18 by madn3ss795 »
Offline TalkingTree
    • My projects
« Reply #241 on: Fri, 08 December 2017, 08:12:22 »
Finally assembled mine.
Offline kekstee
« Reply #242 on: Fri, 08 December 2017, 09:49:28 »
JCEX shipping was fine for me. Tracking worked and it somehow used a fast local carrier. Destination airport to my doorstep over night.
Set aside a NerD60 for this and was happy to see it just fits without complications.
  • Not a real doctor
    • OC Lab Discord
« Reply #243 on: Fri, 08 December 2017, 09:57:57 »
You stole my idea, I'm putting plum on my grey 5° case!  ;D Looking good though  :p
Edit:
The grin and tongue smileys aren't working  :(
« Last Edit: Fri, 08 December 2017, 10:07:14 by dr_derivative »
Offline Rumblehotep
« Reply #244 on: Fri, 08 December 2017, 10:41:56 »
Man that chamfering really makes the cherry profile stand out, can't wait!
Offline smithyithy
  • a l p s
« Reply #245 on: Fri, 08 December 2017, 11:20:58 »
Damn, so many great combos appearing!
Offline Rumblehotep
« Reply #246 on: Sat, 09 December 2017, 14:00:07 »
Just got my dark purple and dark blue cases and had a bit of a panic.
First case is an extremely shiny metallic lavender.
Next case is a very dark rich purple.
Did I get shipped the wrong cases? But there was no light purple option right?
Took them out of my workstation area and into bright sunlight and boom the lavender darkened into an awesome purple and the dark purple one morphed into dark blue.
Moral of the story: I gotta get rid of my yellow lamps, the dark blue case literally changed from left to right in direct sunlight.
  • Not a real doctor
    • OC Lab Discord
« Reply #247 on: Sat, 09 December 2017, 15:29:55 »
Same thing happened to me with my dark grey, at first I thought they'd sent me a silver one by accident  :))
Offline KaosJ
« Reply #248 on: Sat, 09 December 2017, 16:24:37 »
any photo?
Offline HotRoderX
« Reply #249 on: Sat, 09 December 2017, 17:05:30 »
KBParadise v60 doesn't work ((uses similar screw outs to Poker2)) The board uses 3 of the screw placement top is not secure at all. The top ((assuming due to post)) shorts allowing multiple number keys to be pressed with a sing press when using the numbers at the top.
GK64 Doesn't fit at all plate is to wide. The screw outs are not the same. I am pretty dis pointed in this as I asked before joining if it would fit the answer was yes. I had my doubts and worries seems they where founded.
