Author Topic: Model M SSK vs Full Size Model M arrow keys  (Read 2761 times)
Offline DuckNorris
« on: Mon, 18 September 2017, 13:38:17 »
Hello,
Are the full size model M arrow keys the same font and color as the Model M SSK arrow keys? Assuming both are white label Model Ms.
Thank you.
Offline 0100010
  • Not Sure
Re: Model M SSK vs Full Size Model M arrow keys
« Reply #1 on: Mon, 18 September 2017, 14:11:04 »
Depending on age, they can be a little different; but most likely you wouldn't be able to tell any difference.
Worst case, could always get a complete new set from Unicomp; may not look as crisp as the originals, but they would all match then.
