Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
seeking for a way to fit a teensy lc on a custom 105 key
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: seeking for a way to fit a teensy lc on a custom 105 key (Read 2759 times)
sheckta
Thread Starter
on:
Thu, 21 September 2017, 10:30:47 »
hey i just purchased a ducky set of 109 keycaps but i will only use 105 of them and since i mentionned in the title i'd like to use a teensy lc but being totally new to all this i dunno how to go with the matrix because i'm limited to 25 pins...
if anyone out there could help me that would be awesome! thx by advance and hoping to talk to you soonish!!
PS: by the way here's the keycap set i'm talking about
edit: 104 keys not 105
Last Edit: Thu, 21 September 2017, 12:11:39 by sheckta
Logged
Tactile
Re: seeking for a way to fit a teensy lc on a custom 105 key
Reply #1 on:
Thu, 21 September 2017, 11:16:13 »
There might be a better choice for your project. The Teensy LC requires 3.3 volt input on the I/O pins and is
not 5 volt tolerant
. USB is 5 volts so you'd have to deal with that somehow, while other controllers can deal with 5 volts out of the box.
Logged
RE
Λ
LFORCE
sheckta
Thread Starter
Reply #2 on:
Thu, 21 September 2017, 11:19:22 »
i already bought it :/ that's a problem...
Logged
rich1051414
Reply #3 on:
Sun, 24 September 2017, 14:50:58 »
Man, the teensy 2 and teensy 3.2 are 5v tolerate, but specifically the lc is not. I don't think the board uses much power, so you may be able to get away with a voltage divider to convert the 5v to 3.3v. A voltage divider is just two resistors.
Last Edit: Sun, 24 September 2017, 14:56:28 by rich1051414
Logged
Siig Minitouch with Orange Alps, Whitefox 60% Zealios 67g, Realforce 87U 55g Topre,
LFK SMK/Alps TKL With SMK 2nd Gen Cherry MX mount switches
, NEC APC-H412 NEC Blue Ovals, Unicomp Model-M Spacesaver, XMIT Hall Effect, WASD Code Cherry MX Clear, KBDFans75 Lubed Gateron Greens, Azio MGK L80 Kailh Brown, XD84 Pale Blue Box Kailh, NIB Pingmaster TMK Converted, KPrepublic XD96 Blue aluminum case with Jade Box Kailh
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
