Author Topic: Starter here (can OEM profile keycaps be replaced with DCS profile keycaps? )  (Read 6625 times)
Offline ExtenZe
Hello guys ,
so recenty i bought my first mechanical keyboard its a cheap board but i love it so far. Its the Drevo Gramr 84 , however i hate the font , and i want to replace at least the alpharethmetic keys and the arrow keys, here where i live i dont have many options for keycaps so the set below is pretty much the only i can select for now at least  ( except if i wait a lot for shipping and i order the correct keycap set from another country ). So from some reviews it seems like the Drevo Gramr 84 has an OEM keycap profile , the set im thinking of buying doesnt specify the keycap profile , but in the reviews of that set someone pointed out that these keycaps are a DCS profile. As im really new to these things , will the DCS keycaps work perfectly on a board desinged with stock OEM keycaps? ( i mean will the incline change? will the new keycaps bottom out perfectly or will the different incline destroy the typing experience?
keyboard amazon link: https://www.amazon.com/DREVO-84-Key-Mechanical-Keyboard-Backlit/dp/B01K4GNLMS/ref=sr_1_5?ie=UTF8&qid=1506018594&sr=8-5&keywords=drevo+gramr+84+key
keycaps amazon link:https://www.amazon.com/Bossi-keycaps-Double-shot-Mechanical-Keyboard/dp/B01IBM8YZ6
Thanks in advance :D
Offline zslane
Re: Starter here (can OEM profile keycaps be replaced with DCS profile keycaps? )
« Reply #1 on: Thu, 21 September 2017, 13:56:28 »
DCS is very similar to OEM, but a little shorter:
You could replace the entire keycap set with DCS and not really notice much difference, but you can't mix and match them seamlessly.
Offline ExtenZe
« Reply #2 on: Thu, 21 September 2017, 14:03:43 »
well  if only the right shift and right alt and fn keys were standard size , but they arent , normally these are 1.25 units wide but in this keyboard the drevo gramr they are 1 unit wide :/ , the difference indeed seems pretty small , i could use any keys from the numpad (as the drevo doesnt have one ) to fill the previously mentioned keys , but i think i could live with the rest of keys (the non-alpharithmetic keys) being a little bit higher :D , plus orange with black would be pretty sweet looking , but ill see if it bothers me a lot. Thanks!
« Last Edit: Thu, 21 September 2017, 14:05:49 by ExtenZe »
« Reply #3 on: Thu, 21 September 2017, 14:11:13 »
FYI DCS profile is made by signature plastics so unless you are buying from signature plastics and/or from a group buy or individual who bought them in a group buy they are most likely not DCS profile caps.
Here is an older thread on the 'bossi' keycaps https://geekhack.org/index.php?topic=88793.0
Those caps look like OEM profile to me, but OEM profile isn't a standard so YMMV.
« Last Edit: Thu, 21 September 2017, 14:12:58 by SpAmRaY »
Offline ExtenZe
« Reply #4 on: Thu, 21 September 2017, 14:31:00 »
Thanks for the help , i searched i little bit more about the Bossi Keycaps , some dude in a reddit page  asked if they were OEM and a person who had bought them answered "yes" so , they might be after all OEM , i dont know but i think i will take the risk.
