Author Topic: Turning Model F cable into USB  (Read 2018 times)
Offline xueyao
« on: Sun, 24 September 2017, 03:12:29 »
Hi guys! Got a few spare Model F AT and XT cables lying around the house. Is it possible to terminate one end with a miniUSB or microUSB while the other gets passively converted from XT to AT and to USB male A? Are there any limitations or problems that I might run into?
Offline Phenix
Re: Turning Model F cable into USB
« Reply #1 on: Sun, 24 September 2017, 03:20:19 »
Just solder the mini usb plug to the cable (remove DIN connector before), then detach the cable from the pcb, check pin assignment, add concerter, wire it up..
Winter is coming.
Offline xueyao
« Reply #2 on: Sun, 24 September 2017, 04:01:37 »
Thanks for the advice! I'm cutting the end attached to the controller and hooking up a miniUSB there. The other end will be XT>PS/2>USB passively converted.
Offline Phenix
« Reply #3 on: Sun, 24 September 2017, 07:39:38 »
That’s possible. But AFAIK as you go mini USB on one end you could also cut off the DIN plug and solder USB A to it, as there will be no conversation needed.
Winter is coming.
