Author Topic: Does ZZ96 case fit Plate and PCB from RS96?  (Read 2382 times)
Offline toan
« on: Sun, 24 September 2017, 23:50:32 »
Hey guys
I have RS96 with frost acrylic at the bottom. I wonder if the ZZ96 aluminum case will fit PCB and Plate from RS96? If yes, is it easy to install?
Thanks
« Last Edit: Mon, 25 September 2017, 10:39:34 by toan »
Offline TerryMathews
Re: Does ZZ96 case fit Plate and PCB from RS96?
« Reply #1 on: Mon, 25 September 2017, 13:27:06 »
If this (https://geekhack.org/index.php?action=dlattach;topic=67398.0;attach=86561;image) is an accurate reflection of the RS96 PCB's screwholes, then it's identical to the ZZ96.
Offline redbanshee
  • actually Dade Murphy
« Reply #2 on: Mon, 25 September 2017, 14:15:59 »
It will not. The ZZ96 PCB can be put in a RS96 case, but not the other way around unfortunately.
Offline toan
« Reply #3 on: Mon, 25 September 2017, 21:25:41 »
It looks the same to me. But according to redbanshee, it's not fit.. So I'm not sure
