Author Topic: Accidentally spilled coffee on my Topre, best way to clean?  (Read 12764 times)
Offline Ranma13
« on: Mon, 15 March 2010, 14:24:28 »
I accidentally spilled a small amount of coffee in my Topre keyboard and now the 9 and 0 key are sticky. What would be the best way of cleaning up this mess? I pulled the keys and wiped down as much as I could, but it seems like the coffee got inside the switch.
Keyboards: Topre Realforce 87U variable-weight, Filco Majestouch Brown Cherry Otaku, Das Keyboard Model S Ultimate
Mice (trackball): CH DT225, IBM L40, CST LaserTRAC, Kensington Orbit
Mice (regular): Logitech G9, Steelseries Xai, Roccat Kova, Razer Orochi
Offline ch_123
« Reply #1 on: Mon, 15 March 2010, 16:28:21 »
From my understanding of the Topre mechanism, it's quite likely that any damage you've done is reversible. Read Ripster's disassembly articles and clean the gunk out.
Offline TexasFlood
« Reply #2 on: Mon, 15 March 2010, 16:31:47 »
Can you just drench it in alcohol, shake it out and let it dry?
Offline didjamatic
« Reply #3 on: Mon, 15 March 2010, 16:45:23 »
Quote from: ripster;164234
Alchohol and rubber is usually ok.
It works regularly for Millions of college students.
Offline kriminal
« Reply #4 on: Mon, 15 March 2010, 17:22:45 »
erm sell it to me at a reduced price, it isnt going to work anymore...
>_>
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline TexasFlood
« Reply #5 on: Mon, 15 March 2010, 17:24:14 »
Well, if it's a bad idea, don't try it, especially since there are apparently detailed instructions out there already for doing it the right way.
Offline EverythingIBM
« Reply #6 on: Mon, 15 March 2010, 17:29:24 »
Quote from: Ranma13;164190
You should never have liquids or foods near expensive or vintage keyboards. Use a cheap one when dining.
Offline TexasFlood
« Reply #7 on: Mon, 15 March 2010, 17:31:39 »
Quote from: EverythingIBM;164251
Or put one of those plastic covers on it, although some think that even that thin layer of material ruins the experience, on keyboards I mean, :smile:
« Reply #8 on: Mon, 15 March 2010, 19:08:36 »
Quote from: ripster;164263
Don't feel bad.  I spilled tea on my Topre about a week after getting it.  Luckily I knew the drill for opening it up.
But yeah, I wouldn't douse a keyboard in a solvent.  Someone here did that with an ALPS keyboard and kerosene.  I don't think it ever worked right afterwards.  Rubber dome keyboards it's no big deal - $10 down the drain if the keyboard warps or whatever.  Topres you wanna do the minimum.  Just clean the domes/sliders with distilled water and be sure to be patient about drying the whole thing before reassembling.
Are you sure it wasn't beer?
Some rubber domes are pricey. And I don't think it's a good idea to submerge a keyboard in any kind of liquid. I still frown at the whole "dishwasher" thing. It's best just to clean the whole thing by hand if you really want it to be clean.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
Re: Accidentally spilled coffee on my Topre, best way to clean?
« Reply #9 on: Mon, 15 March 2010, 19:28:09 »
Yeah, beer isn't very keyboard friendly...
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline TexasFlood
« Reply #10 on: Mon, 15 March 2010, 19:44:37 »
Drill? Ahh, I knew there had to be a trick...
Offline TexasFlood
« Reply #11 on: Mon, 15 March 2010, 19:47:01 »
I accidentally spilled smores on my keyboard and now I want to eat it...
« Reply #12 on: Mon, 15 March 2010, 20:03:21 »
Quote from: TexasFlood;164302
Smores buckling spring hey? I guess the springs are made from twizzlers?
How about some gummy legos?
Offline HaaTa
  • Kiibohds!
« Reply #13 on: Mon, 15 March 2010, 20:09:15 »
Looks more like J-E-L-L-O to me :P
Kiibohd
Offline TexasFlood
« Reply #14 on: Mon, 15 March 2010, 20:33:38 »
Quote from: EverythingIBM;164307
Could use those to make a yummy version of this:
Offline Ranma13
« Reply #15 on: Mon, 15 March 2010, 20:34:00 »
I managed to open it up and clean the mess, but now I'm having a hard time putting it back together. The rubber domes aren't secured by anything, they just stick onto the PCB. As a result, some of them moved when I opened up the keyboard and now I can't get them to be exactly underneath the keys. Any advice?
Offline Ranma13
« Reply #16 on: Mon, 15 March 2010, 20:52:20 »
Is there any way to tell whether the spring is centered on the contact on the PCB? That's the issue I'm having. My pads look a bit different than the picture you posted as well. Instead of being connected to each other with a lot of gray rubber, they're instead just individual pads by themselves. I'm assuming they did that as a cost-cutting measure.
Offline Ranma13
« Reply #17 on: Mon, 15 March 2010, 21:19:10 »
Thanks, I'll give it a try and report back my findings.
Offline Ranma13
« Reply #18 on: Mon, 15 March 2010, 22:01:23 »
Well that was a complete bust. Not only did I not manage to put it back together, but I also somehow lost one of the springs. I could fret about it some more, but I think I'll just pick up a new one (and get a spill-resistant coffee container while I'm at it).
So if anybody wants it for spare parts or something, it's up for grabs. Just give me the reason why you want it, and I'll pick the best one and ship it to you for free.
Offline MsKeyboard
« Reply #19 on: Mon, 15 March 2010, 22:11:03 »
Don't give up!  Walk away and do something else, come back tomorrow and give it another shot.  This is one keyboard that is worth the extra effort.
Relax and let us know how it goes.............Later
Offline Ranma13
« Reply #20 on: Mon, 15 March 2010, 22:16:01 »
I found the spring!
...Gonna try and put it back together now. However, since I already said I'd give it away, I might as well go good on my word and do so, even if I can put this thing back together.
Offline Ranma13
« Reply #21 on: Mon, 15 March 2010, 23:14:04 »
Alright, I managed to put it back together and I tested all the keys and they all work.
Offline ch_123
« Reply #22 on: Tue, 16 March 2010, 05:44:26 »
Yay!
Does it work as well as it did before the spill? Any stickiness or anything?
Offline hyperlinked
« Reply #23 on: Tue, 16 March 2010, 07:38:03 »
BAH! Way too much effort. Try Giant Gummy on a Stick instead:
Honestly, I come close to retching each time I see the guy take a bite out of the gummy bear's head. I like gummy bears, but this is a bit much.
« Last Edit: Tue, 16 March 2010, 07:41:35 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
