Author Topic: Where can I get PBT only or + POM white keycaps to Sweden?  (Read 6507 times)
Offline Luciqueii
  • 【Luciquell & Co.】
« on: Mon, 25 September 2017, 13:56:13 »
I wanna buy white PBT keycaps to my K65RGB keyboard I have found these keycaps
but the shipping is the same price as the keycaps so I don't wanna pay 40 USD for shipping...
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1330
Someone have any ideas where I can get white PBT keycaps to Sweden without paying overkill price?
Thanks for helping out all in advance!
Re: Where can I get PBT only or + POM white keycaps to Sweden?
« Reply #1 on: Mon, 25 September 2017, 14:20:36 »
Email their support and ask if there are any cheaper shipping options.
Offline JohanAR
« Reply #2 on: Tue, 26 September 2017, 03:02:38 »
Do you have ISO or ANSI layout?
If you're feeling adventurous (description says ANSI but the pictures show ISO layout) you can get this set for 99kr and free shipping: https://www.banggood.com/White-Dual-Shot-PBT-Translucent-104-KeyCap-backlit-for-Cherry-MX-Keyboard-p-1084996.html
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #3 on: Tue, 26 September 2017, 09:28:59 »
WHAT is ISO or ANSI... LMAO sry, idk what it is... I'am beginner at keyboard stuff. PBT keyboard for 99kr...wow
Offline JohanAR
« Reply #4 on: Tue, 26 September 2017, 14:56:56 »
ANSI is US layout while European use ISO layout. Here's a nice comparison: http://www.keybotypo.com/wp-content/uploads/2016/09/ISO-vs-ANSI-min-1024x487.png  Look at enter key and left shift especially. The set you linked looks like it has extra keys to fit both ANSI and ISO. The set I linked seems to have both type of enter keys, but only the wide ANSI left shift so it might not fit if you have a Swedish keyboard.
Also, in case you didn't know PBT is the type of plastic some keycaps are made of, the alternative is ABS which will get shiny after heavy use.
Offline Landcaps
« Reply #5 on: Fri, 06 October 2017, 01:32:03 »
