Author Topic: Cleaning off pad printing?  (Read 4471 times)
Offline LogicLoop
« on: Wed, 27 September 2017, 09:34:35 »
Has anyone deliberately removed pad printing from PBT? I don't want to be too abrasive and scratch the PBT, so would 99% isopropyl alcohol be okay?
Re: Cleaning off pad printing?
« Reply #1 on: Wed, 27 September 2017, 16:14:11 »
PBT will not be harmed by alcohol. It will even take acetone.
Offline Millsoncapo
« Reply #2 on: Thu, 28 September 2017, 03:44:56 »
It depends on your cap is what material, what the process.maybe Amyl acetate?i never do this before.so maybe is not the right way.
« Reply #3 on: Thu, 28 September 2017, 08:46:02 »
pbt is usually dyesub, so you'll have to use abrasive, but that ruins the feel
you can remove pad printing from ABS with some 70% iso and a paper towel
Offline LogicLoop
« Reply #4 on: Thu, 28 September 2017, 18:03:39 »
The keycaps in question are side-printed, which usually means pad printing. On closer inspection of the photographs, they definitely printed on - as the quality is so bad some of the letters are flaking off! This shouldn't be too hard to remove. Thanks for the replies.
