Author Topic: [GB] LZ CLSm (Classic 75) : [Completed]  (Read 105565 times)
Offline brighenne
Re: [GB] LZ CLSm (Classic 75) : OPEN
« Reply #50 on: Tue, 03 October 2017, 11:57:47 »
I clarified over pm that the base kit comes with the acrylic diffuser. The $5 is to add an extra one.
Offline poolside
« Reply #51 on: Tue, 03 October 2017, 14:37:13 »
Will the bags have the LZ logo on the zipper latches or Kin's TX logo?
Just asking because I might need a matching 75% TX bag in the future.
Offline giHefca
« Reply #52 on: Tue, 03 October 2017, 15:27:33 »
What is "white2", "red1", "pink1"?
edit: switch films I guess
« Last Edit: Tue, 03 October 2017, 15:29:27 by giHefca »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #53 on: Tue, 03 October 2017, 20:02:15 »
WAIT ON....  :o
He's actually selling a bag to go with the LZ CLSm?
PMing him now about this...... :thumb: :thumb: :thumb: :thumb:
« Last Edit: Tue, 03 October 2017, 20:03:53 by Elrick »
Offline renzpwns
  • I didn't like money in my wallet anyways.
« Reply #54 on: Tue, 03 October 2017, 20:49:36 »
WAIT ON....  :o
All the boards already come with one, same with CLS TKL. So you really only need to PM if you want extras.  :thumb:
Offline energyd
« Reply #55 on: Wed, 04 October 2017, 17:13:58 »
are the invoices out yet?
Offline Elrick
  • Hype Master
« Reply #56 on: Wed, 04 October 2017, 20:31:39 »
His note, is that the Order deadline will be 2017-10-15.
After that time is reached, he will then send out invoices to everyone involved.
LZ is like a time piece himself, he never changes anything unless something seriously goes wrong.
Offline energyd
« Reply #57 on: Wed, 04 October 2017, 20:58:18 »
Thx! Good to know! Hope this GB go well. :p
Offline n__dles
« Reply #58 on: Wed, 04 October 2017, 21:21:36 »
Won't non-anodized aluminum slowly oxidize?
« Reply #59 on: Wed, 04 October 2017, 21:44:57 »
the point is to get it finished yourself
Offline Unforgivable
« Reply #60 on: Wed, 04 October 2017, 23:41:17 »
LZ,
Just to make sure, the LZ CLSM comes with a free diffuser, correct?
Offline Elrick
  • Hype Master
« Reply #61 on: Wed, 04 October 2017, 23:48:02 »
He's the ONLY keyboard manufacturer that actually finishes his projects on time and within budget  :thumb: .
Something others need to pay attention here, when offering anything similar.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #62 on: Thu, 05 October 2017, 00:12:41 »
Is it October 15th already?
« Reply #63 on: Thu, 05 October 2017, 02:13:28 »
LZ,
yes it does, read up a bit
Offline skaloola
« Reply #64 on: Fri, 06 October 2017, 04:30:47 »
Guess the subject should no longer say "OPEN"
Code: [Select]
This form is no longer accepting responses, and has been set to automatically close by lifezone2@gmail.com
Offline LifeZ
  • LifeZone
« Reply #65 on: Fri, 06 October 2017, 07:31:12 »
« Last Edit: Fri, 06 October 2017, 10:30:38 by LifeZ »
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #66 on: Fri, 06 October 2017, 10:23:53 »
Please confirm your order.
Order deadline 2017-10-15
Order Check
LZ Limited
Offline Prime8
« Reply #67 on: Fri, 06 October 2017, 19:48:46 »
Order looks good. Thanks for the update. Now if I could only hit fast forward on the calendar.
Offline Elrick
  • Hype Master
« Reply #68 on: Fri, 06 October 2017, 22:11:49 »
You can then experience how quickly your 'End of Life' arrives, to welcome you with open arms  ;) .
Enjoy the time as is, instead of wishing it away for a keyboard.  Before you know it, LZ will finish and post everything off to all those who have paid up front.
Offline kidcongo
« Reply #69 on: Sat, 07 October 2017, 04:38:06 »
Order Check
Looks good but the order form said non-ano $425 is that still correct?   Not a deal breaker  but every little helps!
Offline skaloola
« Reply #70 on: Sat, 07 October 2017, 04:56:54 »
Think I'd probably get in on this if the bottom row had support for 3 keys left of the space bar instead of 2. (Winkey, the IC thread shows support for it but here it does not)
« Last Edit: Sat, 07 October 2017, 05:11:06 by skaloola »
Offline renzpwns
« Reply #71 on: Sat, 07 October 2017, 06:06:47 »
It does support winkey as seen on the layouts pic and the cutouts on the polycarbonate plate.
Offline LifeZ
  • LifeZone
« Reply #72 on: Sat, 07 October 2017, 08:49:18 »
Support bot row check~
https://geekhack.org/index.php?action=dlattach;topic=91775.0;attach=179189;image
LZ Limited
Offline skaloola
« Reply #73 on: Sat, 07 October 2017, 09:58:44 »
Thanks for clarifying, for some reason only top picture was loading.  didn't see pic with bottom row layouts
Offline giHefca
Re: [GB] LZ CLSm (Classic 75) : Order confirm
« Reply #74 on: Sat, 07 October 2017, 17:52:45 »
Offline IAmPyhrra
« Reply #75 on: Sat, 07 October 2017, 19:24:23 »
Order looks good.
Offline hoanglh94
« Reply #76 on: Sun, 08 October 2017, 08:35:28 »
I confirm mine
Offline klove4252
« Reply #77 on: Sun, 08 October 2017, 09:00:13 »
Mine looks good
Sent from my SM-N950U1 using Tapatalk
Offline trikoi00
  • GMK bias
« Reply #78 on: Sun, 08 October 2017, 10:36:51 »
I confirm my order.
Offline LifeZ
  • LifeZone
« Reply #79 on: Sun, 08 October 2017, 10:42:50 »
Mine looks good
Hey, plz check your order. yellow mark!
LZ Limited
Offline klove4252
« Reply #80 on: Sun, 08 October 2017, 10:58:48 »
Mine looks good
Sorry about that. I meant to order two extra PCBs and then one extra STS switch plate and one extra Polycarbonate switch plate. Does that clear the issue up?
Offline LifeZ
  • LifeZone
« Reply #81 on: Sun, 08 October 2017, 11:15:59 »
Mine looks good
Base kit 1 include 1 switch plate.
Your order 2 base kit but 1 switch plate choose. More 1 base plate
LZ Limited
Offline klove4252
« Reply #82 on: Sun, 08 October 2017, 11:28:53 »
Mine looks good
Then one additional aluminum plate. I hope that clears it up
Offline techfresh
« Reply #83 on: Sun, 08 October 2017, 11:33:38 »
Confirmed. Order looks good.
Offline SolidCactus
« Reply #84 on: Sun, 08 October 2017, 11:52:13 »
Offline LifeZ
  • LifeZone
« Reply #85 on: Sun, 08 October 2017, 12:02:33 »
Mine looks good
okay, base 2 kit include alu switch plate and extra pc plate + pcb, right??
LZ Limited
Offline klove4252
« Reply #86 on: Sun, 08 October 2017, 12:07:03 »
Yes thank you
Offline klove4252
« Reply #87 on: Sun, 08 October 2017, 12:07:23 »
Mine looks good
Yes thank you
« Reply #88 on: Sun, 08 October 2017, 13:46:21 »
For some reason, a few people PM'd me last night asking to change order details.
Don't do that. I'm not involved with this GB.
Offline poolside
« Reply #89 on: Sun, 08 October 2017, 13:58:36 »
This might be because you have been posting a lot these past few days   ;D
Offline sroop
« Reply #90 on: Sun, 08 October 2017, 14:37:20 »
Confirmed. Can't wait!
Offline JazzThing
« Reply #91 on: Sun, 08 October 2017, 16:23:50 »
Sorry to bother, but I do not understand how to confirm my order.
Offline loud_asian
« Reply #92 on: Sun, 08 October 2017, 16:26:09 »
You don’t need to do anything
If the order has problems, then you PM LZ. if it doesn’t, he’ll just invoice you according to what’s on the spreadsheet. All y’all sayin confirmed are just bumping the thread unnecessarily
Offline JazzThing
« Reply #93 on: Sun, 08 October 2017, 16:30:00 »
Thank you Loud_asian.
Offline poolside
« Reply #94 on: Sun, 08 October 2017, 16:45:11 »
Hey skaloola, the order list has been rearranged by color, yours is now at #15.
Offline mechamode
« Reply #95 on: Mon, 09 October 2017, 00:19:15 »
Order looks good.
Offline Elrick
  • Hype Master
« Reply #96 on: Mon, 09 October 2017, 00:33:31 »
Order looks good.
Thus far 57 people have jumped in on this, schweeet   :thumb: .
Only hope it's not too many wanting this latest creation off him, his OCD on Perfection is quite extraordinary but he never gives up on any project he starts.
Can't wait when he finishes a few keyboards and start showing them via pictures, then that will be something to behold.
Offline LifeZ
  • LifeZone
Re: [GB] LZ CLSm (Classic 75) : INVOICE
« Reply #98 on: Tue, 10 October 2017, 21:00:19 »
INVOICE SENT~~@@  ;)
LZ Limited
Offline Elrick
  • Hype Master
« Reply #99 on: Wed, 11 October 2017, 18:13:28 »
INVOICE SENT~~@@  ;)
And Paid in FULL, now lets get this baby started   :thumb: .
