Author Topic: Self built 60% (mostly questions)  (Read 10506 times)
Offline Denisgsv
« on: Thu, 28 September 2017, 09:04:00 »
Hello everyone been lurking for a while, decided i wanted to try and built a proper keyboard myself.
So so far i havedecided i wanted the case from kbdfans : 5° 60% keyboard aluminum case
Switches probably: zealios 67 (accepting some advice here , havent tried them YET, ppl say they are amazing tho)
My main issue atm is finding a decent PCB, i would like also to be able to mod it with holtite sockets. ok no holtite sockets, it seems soldering good ol' way is better
I'm also not sure if i should buy the "plate" toghether with PCB or with the case ? ok seems plate and pcb should be in combo
must have : case, pcb, plate, switches, keycaps, holtite sockets(switches)
nice to have : custom cable, leds, holtite sockets(leds).
So far kbdfans has both pcb and plate (with split space bar) i didnt knew i want, but i know now.
Other solution is banana split. (need to wait for november)
so any advice ?
thanks
« Last Edit: Fri, 29 September 2017, 08:35:44 by Denisgsv »
Offline Zobeid Zuma
Re: Self built 60% (mostly questions)
« Reply #1 on: Thu, 28 September 2017, 09:21:45 »
I am in a similar boat, getting ready to build my first.
The new one they are now taking pre-orders for?  It does look good.  I may get one too, although I've already put in my order for the Teamwolf heavy aluminum case.
Have you examined any of the new Kailh BOX switches?  They've won me over.
I believe the plate should generally be matched to the PCB, unless you get a case with the plate integrated (like a Clueboard kit).
BTW, a lot of Outemu switches now come with sockets.  I tried the Outemu ICE Purple switches, which are basically Zealios clones, and they seem pretty good.  However, I don't think the sockets are compatible with other brands, so you'd only be able to swap between other Outemu switches.  (Which are generally good.  I'm also fond of Outemu blues.)
Getting a PCB has also been a challenge for me, especially since I am very determined that I want a split space bar, and most of them don't support it.  I ordered a new DZ60 PCB from KBDfans.  I haven't heard too much about that one, so I guess I'll find out for myself.  And if that doesn't work out (or even if it does, probably) I'll be up for round 2 of the Banana Split 60 kit, which is supposed to be unveiled around the end of October.  That's what I really want, but I am impatient.
Offline Denisgsv
« Reply #2 on: Thu, 28 September 2017, 09:42:51 »
Yes that case, it seemed good value for only 80$, worst case scenario if i will give up or find something else i should be able to sell it probably without huge loss (tho 80 in this business seems a good price)
Kalih, nope. Havent searched for them to be honest, there are just soo many.
Each time i think i found the one there is the next one which seems a tiny bit better, (thats why i avoid topre)
If i like browns, i assume i should go for Kalih browns aswell ?
Same thing with outemu like above, as i understood they have something which works like this : https://kbdfans.myshopify.com/collections/keyboard-part/products/switch-led-hot-swap-32pcs
Is that corect ? Instead of making the PCB swapable, u make switches so ?
ill check the banana split,  my project will surely be a lot slower.
Never thought about split spacebar, now it makes so much sense.
Offline ideus
  • Björkö.
« Reply #3 on: Thu, 28 September 2017, 10:00:37 »
As a reliability engineer, using sockets for switches makes no sense at all. It adds another layer of potential circuit failures. Having a notched plate for switch's internals refitting makes a more elegant solution, for trying other MX switch's stems or springs.
Offline Denisgsv
« Reply #4 on: Thu, 28 September 2017, 10:18:08 »
but a notched plate still needs pcb to have holtite sockets is that right ?
Cant i combine notched plate + sockets for swapable switches ?
« Last Edit: Thu, 28 September 2017, 10:21:17 by Denisgsv »
Offline Zobeid Zuma
« Reply #5 on: Thu, 28 September 2017, 11:15:47 »
I have some difficulty buying directly from Chinese companies.  I wish somebody would import and distribute this kind of stuff.
The basic Kailh brown switch is yet another Cherry MX brown clone.  It's a good one, at least as good as Cherry IMHO, but. . .  All these brown switches, you put them on a tester side-by-side, and you can detect subtle differences, but then put them on an actual keyboard and type, and I think you'd never know which was which.
The new Kailh BOX switches are something else.  They are partially sealed to make them resistant to dust and liquids, and they feel-and-sound different from the regular clones.  The tactile ones have their "bump" right at the beginning of key travel, then it's smooth to the bottom.  The box brown is the regular version, and burnt orange is the same thing with a heavier spring.  Based on playing with the samples, I'd love to build a keyboard with them.  However, I got the samples from NovelKeys, and they are sold out right now.
Also FYI, the BOX white and pale blue are the clicky versions.  They have a unique double-click, a sharp click when you press down and another when you release.
Looks like the same idea.  The pins have tiny aluminum sleeves on them, so you solder the sleeve into your PCB, then later the switch can be pulled and replaced without desoldering.
Offline ideus
  • Björkö.
« Reply #6 on: Thu, 28 September 2017, 11:36:54 »
No. Switch's bottoms are soldered directly to the PCB and you only disassemble the tops to change the internals. The switch's connections are permanents, therefore reliable.
Offline Denisgsv
« Reply #7 on: Thu, 28 September 2017, 12:57:31 »
So basically you advice for plate + soldering into pcb, no holtite sockets. (fair enough) it does make sense i gues.
Zobeid Zuma
Atm i really like the banana pcb, was wondering does that bottom (double space bar) row create any problems with finding the keycaps ?
Offline Zobeid Zuma
« Reply #8 on: Thu, 28 September 2017, 16:33:27 »
I think those key sizes were chosen so you can use standard shift keys as spacebars, which is what I've seen done on most of the builds.  I'd like to get actual convex spacebars, which are hard to find, but they do exist.  Or if that fails, it may be possible to have them 3D-printed.  Where there's a will there's a way.
Offline Denisgsv
« Reply #9 on: Thu, 28 September 2017, 16:42:07 »
btw you mentioned DZ60 PCB from keyboard fans, i realised now it can have double space bar, but the plate for it : CNC 60% Aluminum Plate, seems not to support 3 buttons instead of a space bar ?
If that is indeed so, what plate did you choose ?  :-[
Offline Zobeid Zuma
« Reply #10 on: Thu, 28 September 2017, 17:41:05 »
If you buy it through their store on AliExpress here -->  https://www.aliexpress.com/item/DZ60-Custom-mechanical-keyboard-PCB-60-keyboard-support-arrow-key/32824638057.html
. . .there does appear to be a kit option that includes the proper plate with support for split space bars.  I'm not sure why that isn't available if you buy through the kbdfans.myshopify.com site.
Keyclack.com also produced a very limited run of 60% universal brass plates that included split spacebar support.  It looks like they only sold a few of those -- but I found somebody who used one on his Banana Split build and thus had the original steel plate left over, so I'm getting that.
Worst case scenario, it's always possible to have a plate custom made by a waterjet or laser cutting service.  (Or just PCB-mount everything and not use any plate at all!)
Offline TalkingTree
    • My projects
« Reply #11 on: Fri, 29 September 2017, 07:32:45 »
Europeans can buy PCBs from a few different stores such as Falbatech for the GH60 rev C, Candykeys for the FaceW sprit's edition or Mekanisk who used to sell GON NerD60.
Plates are not mandatory.
Offline Denisgsv
« Reply #12 on: Fri, 29 September 2017, 08:19:01 »
Grazie mille
I checked Mekanisk seems under reconstruction.
The other two do indeed sell pcb plates, will check later if they also support split space bar.
(even if plates arent mandatory)  i have already a certain number of switches and all are to be used with plate, and also for aesthetics i would like a plate ... so its kinda a must have for me at this point.
Offline TalkingTree
    • My projects
« Reply #13 on: Fri, 29 September 2017, 08:25:39 »
Mekanisk is run by our fellow geekhacker LeandreN, you can PM him.
Neither do.
That's wise as plates add rigidity and stability.
Offline Denisgsv
« Reply #14 on: Wed, 18 October 2017, 02:42:37 »
need some help, how do i learn qmk ?
intend to have this layout :
https://i.imgur.com/SCiWXOe.png
But i wanted to change it a bit, make ESC a proper esc. Make button near "right shift" into this "<>" <--- ISO layout.
Caps lock and right windows into "fn" (pok3r style)
I never used QMK yet but i understand it can do anything so that should be possible, so where do i start, do i need to make it all from scratch or can i only change the things i need ?
Any help is apreciated, thanks.
Offline TalkingTree
    • My projects
« Reply #15 on: Wed, 18 October 2017, 03:57:53 »
You need to define your own keymap and you can use the one in the default subfolder of your PCB. Which one is it?
Offline Denisgsv
« Reply #16 on: Wed, 18 October 2017, 04:01:14 »
Well, i expect it will have a default one, i was thinking i could start there.
First i want to "fix" default layout so to speak, then i want to fn+x layout.
If that is possible.
the stuff i found is this :
https://drive.google.com/file/d/0B9XoYZuzpjWnMDhvd0gyYnBjYU0/view
https://drive.google.com/file/d/0B9XoYZuzpjWndDFrTm9waVRtY0JrREVxWTRBSlpYa3JmX3pv/view
But i dont see any layout in neither of them which can be configured, hence the question ...
Offline TalkingTree
    • My projects
« Reply #17 on: Wed, 18 October 2017, 04:06:19 »
Download QMK from github.
Navigate to ./keyboards/_YOUR_PCB_/keymaps/default and edit the keymap.c file to your liking.
Compile the source and flash the hex file to your MCU with your favourite method.
Offline Denisgsv
« Reply #18 on: Wed, 18 October 2017, 04:31:28 »
Ok, nice i found the layout. By the look of it "standart layout 0" should be easy, insert buttons i need in correct places.
still no idea how to program layers but ill figure it out (hopefully)
what i wanted to ask about :
  Compile--> any advice with what ? and what exactly is "the source" my knowledge in programing is limited and even more in C.
  What and where is the hex file, and i dont have any methods (never done it) so an advice on what method to use ?
grazie ancora  :-X
Offline TalkingTree
    • My projects
« Reply #19 on: Wed, 18 October 2017, 05:57:21 »
Copy and paste your layer and make the changes you like, it will count as a different layer and it will be accessible with a Fn button. You can either make it momentary, so the layer will be active only when the Fn button is held down, or toggled so you need to press the Fn button again to return to the main layer. Needless to say you need to define the Fn key on the secondary layer as well. This keymap should give you the idea.
The official documentation will surely explain the process better than I could possibly do. The .hex file will be saved in the qmk/keyboards subfolder. You then need to flash the MCU but let's start compiling the source first.
grazie ancora
Figurati.
Offline Denisgsv
« Reply #20 on: Wed, 18 October 2017, 07:21:40 »
came across this nice configurator made the default layout.
http://www.keyboard-layout-editor.com/#/gists/1a23f89fd9ddc574e46661b4bae62aa1
trying to see how to combine that with : http://www.kbfirmware.com/
Offline TalkingTree
    • My projects
« Reply #21 on: Wed, 18 October 2017, 07:37:31 »
You need to paste the raw data output from the KLE into the configurator, select the board and generate the firmware.
Also keep in mind that you need to use the standard ANSI layout to generate your firmware. Your computer will translate the scancodes into the italian characters.
« Last Edit: Wed, 18 October 2017, 07:39:21 by TalkingTree »
Offline Denisgsv
« Reply #22 on: Wed, 18 October 2017, 08:21:32 »
i tried what you just said, could not select the board (it wasnt there)
he created this wiring : https://i.imgur.com/PIV3ZU0.png
need to find dz60 wiring to compare if its corect.
a bit confused about what i need to map here : https://i.imgur.com/1O6FbJV.png
i think that's what you meant that i need to use "standard ansi layout", if i understood correctly i should map into those buttons something like this : https://i.imgur.com/jXSe9Zt.png
i suppose the computer knows already what characters are on "shift + modifier"  so i need to map only layers i want as bonus (for example layer1,2)
lets assume problems above are solved, i have hex file, what should i do with it ?
Offline Denisgsv
« Reply #23 on: Wed, 18 October 2017, 08:44:37 »
found this :
http://qmkeyboard.cn/
same thing as above but chinese .... With a smilar layout listed there.  DZ60带方向配列
but it has splited backspace ( 2 buttons instead of 1 )  ... ansi enter.
i'm still not sure what character goes on ISO keyboard between left shift and Z/Y.  Ansi keyboards totally miss that character :|
Offline ideus
  • Björkö.
« Reply #24 on: Wed, 18 October 2017, 08:46:15 »
The picture you referred to shows an ISO layout with non standard right shift and arrows. It is not the standard ANSI layout.
Offline Denisgsv
« Reply #25 on: Wed, 18 October 2017, 09:13:58 »
i referred lots of pictures ... Which one ?
From my understanding i should map this : https://i.imgur.com/RDSx1bh.png ? is that right?
Offline TalkingTree
    • My projects
« Reply #26 on: Wed, 18 October 2017, 10:11:00 »
The QMK github repository already contains the DZ60 build so you don't need to configure any wiring, but your keymap alone. You can surely use those websites to compile your firmware granted that you provide the keymap with the raw data output from the KLE.
Make sure that the key next to Left Shift is set to NUBS which stands for Non US Backslash, in other words, the extra key on ISO keyboard.
Correct.
Yes. The computer will receive scancodes from your keyboard and translate them to characters according to the encoding you defined in your operating system; most likely Italian (Italy).
Flash it to your MCU. There are a number of ways to do that, such as using FLIP or the dfu-programmer.
Offline Denisgsv
« Reply #27 on: Wed, 18 October 2017, 11:48:56 »
ok so far :
i made the layout in KLE (hope got mapping right)
transfered it succesfully into kbfirmware (hope again layout is correct)
Only one question ... if generated "wiring" is ok.
Offline Denisgsv
« Reply #28 on: Thu, 19 October 2017, 03:42:52 »
found another guy who had a problem with qmk and dz60 pcb, it seems you need to configure pins correctly
https://i.imgur.com/VtcNzDr.png
leaving this here, one never knows it may be usefull.
« Last Edit: Thu, 19 October 2017, 03:48:24 by Denisgsv »
Offline Zobeid Zuma
« Reply #29 on: Thu, 19 October 2017, 04:06:22 »
Not sure why you would need to reassign any pins.  That should all be taken care of in the default DZ60 code.
Offline Denisgsv
« Reply #30 on: Thu, 19 October 2017, 04:12:36 »
well there is no default code, you start from scratch in the web configurator. in chinese version there are a few dz60 configurations but none of them is like mine.
