Author Topic: Suggest Some PBT Ninja Style Keycaps For My Das Professional  (Read 3669 times)
Offline Intex
« on: Wed, 04 October 2017, 01:43:40 »
Hello,
I am in the market for some new keycaps for my das professional, purchased in 2011. It is a 105 key layout.
What I am looking for:
- Black color
- PBT
- Ninja style (side printed)
- High quality
What would you guys suggest? I was looking at these 2 options on mechanicalkeyboards.com but am not sure which is right for me or if there is a significant difference, or if better options exist.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1806
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1336
Thanks geekhackers!
Re: Suggest Some PBT Ninja Style Keycaps For My Das Professional
« Reply #1 on: Wed, 04 October 2017, 05:09:33 »
I'm a fan of Leopold's side print pbt but I'm not sure if the das board has a standard layout or not.
Also the 2 sets you linked are out of stock.
« Last Edit: Wed, 04 October 2017, 05:11:32 by SpAmRaY »
Offline Intex
« Reply #2 on: Wed, 04 October 2017, 10:35:52 »
I would love to buy leopold side print caps! I have a leopold fc900r and the keycaps are amazing. Where can I buy the leopold caps? Can anyone confirm whether the leopold caps will fit my das?
Also I dont care if stuff is out of stock. The good stuff on mechanicalkeyboards is always out of stock. I dont mind waiting 6 weeks.
With regards to the layout, my das looks a lot like the model s professional (it does not have the oversized volume wheel). Not sure if this helps
« Last Edit: Wed, 04 October 2017, 10:37:25 by Intex »
