Author Topic: help me find the right keyboard for work  (Read 2057 times)
Offline Kraicheck
« on: Wed, 17 March 2010, 05:29:05 »
I'm looking for a keyboard that I can take to work. Because I have to use it there, a couple of constraints follow:
- QWERTY (ANSI or ISO) or AZERTY layout with lettering
- not too loud
- preferably full layout (so no tenkeyless)
- transportable/compact: I'll most likely have to take this with me to work and back home every day.
Other constraints:
- Because the standard right CTRL key is far from an easy reach and because I can't use any registery remappings, I also need the right CLTR key to be closer to the spacebar. At least at the location of the Application key.
- It should be available in the EU. Apparently customs is a nightmare in Belgium.
- At least one windows key.
I'm flexible in the type of switch but prefer something along the lines of cherry browns.
I guess I should be looking at Cherry boards?
Offline trievalot
« Reply #1 on: Wed, 17 March 2010, 05:33:27 »
browns are good, cant go past the Filco (availible in europe)
i know someone else will suggest a board with dip switches. buy em if you can afford em.
[SIGPIC]
Offline Kraicheck
« Reply #2 on: Wed, 17 March 2010, 06:14:33 »
All Filcos do have the right CTRL too far away though.
This constraint really narrows down my possibilities but it's one I don't want to compromise on. It's funny how you almost can't find a rubber dome without the layout that I want, but mechanical keyboards all hold on to this (IMO) crappy right CTRL location which would be better suited for a less used key.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #3 on: Wed, 17 March 2010, 06:28:40 »
I'd recommend the Cherry 1800 layout. But...finding them with an MX switch is a bit difficult (i.e. if you find one, let me know, I want one). It's definitely my favourite layout (though my current Model F layout comes close with the left hand Function keys and the close to backspace Esc).
Don't go for the MY switches (G81) unless you know what you're getting yourself into.
« Last Edit: Wed, 17 March 2010, 06:31:12 by HaaTa »
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline trievalot
« Reply #4 on: Wed, 17 March 2010, 06:32:32 »
Quote from: HaaTa;164730
depends if you care about the not too loud bit.
These sound like the horses of the apocolypse charging when typing
Not a bad thing by the way, quite satisfying in fact
« Last Edit: Wed, 17 March 2010, 06:36:30 by trievalot »
[SIGPIC]
