Author Topic: Please help me choose a TKL base  (Read 3024 times)
Offline mudcakehoney
« on: Fri, 06 October 2017, 20:33:41 »
I want to build a TKL board from ground up and looking for a good black base, something aluminium compact looking with a nice angle a solid ‘tough’ design with maybe a retro styling. Have pre ordered the Led Zep keys so trying to match that.
Your suggestions appreciated.
Offline raxander
Re: Please help me choose a TKL base
« Reply #1 on: Fri, 06 October 2017, 21:46:38 »
« Reply #2 on: Fri, 06 October 2017, 22:04:42 »
Something like this maybe?  https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=280
I like the look of the Filco simple but elegant
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Sat, 07 October 2017, 17:21:02 »
You can get a used older CM Quickfire Rapid for cheap and then mod the hell out of it. It's compatible with a lot of custom cases and has a few custom controllers made for it. They are basically Filcos (same OEM) with cheaper cases and caps.
I did notice on the PCB it's a bit easy to burn or lift the pads while soldering but otherwise it's awesome.
« Reply #4 on: Sat, 07 October 2017, 17:37:07 »
Ok nice, that might be a good project for my first build. Wouldn’t be a as large a price point to begin with. Some of the base+pcb’s going on GB are really expensive
Offline klennkellon
« Reply #5 on: Sat, 07 October 2017, 17:55:11 »
Yes it's ridiculous. QFR is cheaper and easier. You just have to do a lot of desoldering if you wanna swap the switches.
You do get a bunch of free switches out of it too that you could sell.
