Author Topic: Tiling window managers mmm  (Read 43661 times)
Offline iLLucionist
  • Topre is Love.
« on: Sun, 08 October 2017, 06:04:25 »
Ever since I converted to 3 monitors, I switched to i3, a tiling window manager. Instead of using the mouse, I can switch between windows just using keys, actually increasing my productivity (Law of Fitts).
Are you using on of dem tiling window managers? Which one? And why?
Offline joey
Re: Tiling window managers mmm
« Reply #1 on: Sun, 08 October 2017, 06:07:36 »
I've used dwm for many years.
Unfortunately I only have a mac at home. But luckily the screen is small enough to just only have one window open at a time.
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Sun, 08 October 2017, 06:10:09 »
That's actually one of the reasons why I switched away from Mac... window management. No Mission Control helping me there, didn't like it. I've tried tiling apps on the Mac, but I didn't like them.
Dwm is nice! :thumb:
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sun, 08 October 2017, 07:20:04 »
I have a 38" 3600×1600 screen estate, and use KWin with hotkeys for tiling windows and "focus follows cursor" for switching windows (just pushing the mouse/trackball in a general direction is quite effortless).
Offline iLLucionist
  • Topre is Love.
« Reply #4 on: Sun, 08 October 2017, 08:01:42 »
That's nice. i3 has mouse focus by default. But what I really need to be productive is:
alt + left / right = move to left right window
alt + num = move to desktop <num>, for instance my left screen is 1, my right screen is 3.
shift + alt + left / right = move window to left or right
shift + alt + num = move window to desktop <num>
shift + j / k = move whole desktop to left / right screen.
Offline davkol
« Reply #5 on: Sun, 08 October 2017, 09:03:10 »
Over the years, I've figured I don't want to deal with hidden windows. The mental overhead is too damn high—compared to simply tilting my head to another [part of a] screen.
So, I have only a bunch of hotkeys on Super + some keys around IJKL.
The main reason why don't use an obscure window manager is that it's too much work, especially if I decided to ditch the desktop environment (Plasma) and setup everything manually.
Another reason is that the minimalist window managers are usually useless with only a pointing device and a touchscreen specifically. Sometimes I simply want to sit back and read without a keyboard getting in the way (my other PC is a convertible tablet and I'm thinking of getting a controller—instead of a trackball/touchpad—for my desktop too).
Offline iLLucionist
  • Topre is Love.
« Reply #6 on: Sun, 08 October 2017, 09:32:30 »
I can see that. My desktop is not touch, so I don't mind having to rely on keyboard and mouse.
Hidden windows is annoying. At my office, I only have 1 22" monitor. It's near to useless, so I work from home more and more. As a matter of fact, I would like to have 5 27" screens now (3 currently). But I don't now whether you need to tilt your head too much for that to be efficient and usable.
Offline davkol
« Reply #7 on: Sun, 08 October 2017, 09:44:39 »
I find the field of view occupied by a ~40" screen at arm-length distance to be borderline. Any larger and I'd have to put it further away, or move around instead of just tilting the head.
Based on current state of market, I'd get 4k @ 32" screen, but then… I can't justify the cost compared to what I have now.
Offline iLLucionist
  • Topre is Love.
« Reply #8 on: Sun, 08 October 2017, 09:58:48 »
Just one 32"? Or 3?
As a (systems / web) programmer, I basically never have enough space. I use i3 + tmux + vim + firefox for dev and I always have around 10 files open simultaneously, and switch between them constantly. My screen in front code, my screen right is second tmux session with more code and firefox with documentation. My left screen is e-mail + autoreload webpage. I would like to have another screen JUST for code. I guess I should have a 32" in front of me to see more code at once or something. That would be great actually.
And now, I have some production servers I want to monitor continuously, so I am already thinking of buying another 24" screen with a raspberry pi or something to have the screen always on to look at stats (of course with proper monitoring and e-mail triggers, but you get the point).
Offline bearz42
« Reply #9 on: Sun, 08 October 2017, 11:53:29 »
ghhhh I love i3 so much.
I have it on my laptop, which is hooked up to an external monitor. I have it set up to put odd workspaces on the laptop, even on the monitor. I honestly can't even imagine going back to a floating window manager. I've actually tried other tiling wm's as well but I just can't get the hang of them the way I have the hang of i3.
To me it's the perfect window manager. Easy to use/configure and out of the way so I can get other stuff done. Also, I love being able to have like 3-5 windows open while I'm programming. I can look at older code in one window, vim in another, compile and test in a different one, switch to another workspace to look something up online or to change my music.
It's stupidly convenient.
Offline iLLucionist
  • Topre is Love.
« Reply #10 on: Sun, 08 October 2017, 12:16:16 »
i3 is great.
And on a new install, the only thing I need to do is:
ln -s ~/dotfiles/i3conf ~/.i3/config
Offline bearz42
« Reply #11 on: Sun, 08 October 2017, 12:32:56 »
i3 is great.
Yeah, that's the other perfect part about it. I just copy my old config and there I go. I tried bspwm as well as dwm. I absolutely see the merit in both but to me, it's not even worth the hassle of learning.
Are you just using the regular i3status bar? I've thought about changing it but three years into i3 and I still haven't.
Offline iLLucionist
  • Topre is Love.
« Reply #12 on: Sun, 08 October 2017, 12:34:16 »
i3 is great.
I use i3blocks. Initially, because I wanted to use fontawesome for the icons before the stats. But eventually, I kept text descriptions.
Offline davkol
« Reply #13 on: Sun, 08 October 2017, 12:47:00 »
Just one 32"? Or 3?
One. I don't need to monitor anything and anything beyond my 3-5 windows (basically 2× source, documentation, output or something along those lines) is mostly distractions that reduce productivity.
That 32" alone is 70cm wide, I can't do more than 90-100 cm.
Offline iLLucionist
  • Topre is Love.
« Reply #14 on: Sun, 08 October 2017, 12:50:22 »
Just one 32"? Or 3?
I'm looking towards buying this.. ASUS ROG SWIFT PG348Q
https://www.asus.com/nl/Monitors/ROG-SWIFT-PG348Q/
Offline JohanAR
« Reply #15 on: Tue, 10 October 2017, 07:54:51 »
Using i3 at work but at home I prefer xfce since I rarely have many windows open at the same time
Offline iLLucionist
  • Topre is Love.
« Reply #16 on: Tue, 10 October 2017, 17:30:27 »
I like XFCE. When I don't have tilings needs I also use XFCE. Lightweight, fast, feature-full. Only thunar is unstable for me sometimes..
Offline jjanssen1
« Reply #17 on: Tue, 10 October 2017, 20:12:57 »
I use chunkWM on my school macbook a lot of the time(switched back from linux for now until I fiqure out how to get better battery life (and until I get a bigger SSD)).
IBM Model M 1386303
Offline sth
  • 2 girls 1 cuprubber
« Reply #18 on: Tue, 10 October 2017, 20:18:56 »
i've been using cwm for years now - it's a floater but still heavily keyboard based (you can config it to do anything mouse-related on the keyboard).
tiling wms just never really spoke to me, but cwm has a pseudo tiling feature that i use sometimes to organize my workspace temporarily. I like having a floating-first WM that gives me the option to tile rather than tiling by default. i know you can set that up with other tilers but cwm is pretty neat if you don't need advanced tiling stuff.
otherwise i can alt tab all day and night, works fine for me. i have been thinking of switching back to dmenu from cwm's built in launcher and compiling with runorraise so i can switch that way, too.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #19 on: Wed, 11 October 2017, 18:29:35 »
Yep i3/i3blocks. There is no dotfile endgame for me
Offline iLLucionist
  • Topre is Love.
« Reply #20 on: Thu, 12 October 2017, 11:26:28 »
Mmmmmm that's tasty!
Offline yuppie
« Reply #21 on: Thu, 12 October 2017, 11:54:32 »
I used to use SubtleWM and BSPWM.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #22 on: Thu, 12 October 2017, 12:55:59 »
Aww shucks. I've had a bit a fun poking at configs and seeing what's what.
Offline TacticalCoder
« Reply #23 on: Fri, 13 October 2017, 20:31:41 »
I'm using the (tiling) Awesome WM on Debian Linux (stretch). I'm so used to that WM I don't even remember when I switched.
So that tiling WM and about 10 "workspaces", each with their own layout/program open, mostly all usually laid out always the same way. For example workspace 1 is for personal email + two terminals, workspace 3 is for Emacs + development browser + one terminal, workspace 4 for all my SSH sessions, workspace 8 for browser, workspace 9 for programs I don't use often.
I've got one additional modifer (hyper) that is dedicated only to the WM shortcuts and WM shortcuts are only available through this modifier. I think that's what I liked when I tried Awesome WM: I'm sure i3 or XMonad or whatever would do too but basically it was a one-line change in Awesome to use Hyper as a modifier for all my WM shortcuts.
I only use the mouse for browsing: I switch between windows using shortcuts. I don't have that many windows at once on a single workspace: two to four windows typically.
Setup is not rigid: I can still change layout, move windows between workspaces, open new terminal, resize windows, etc. all with one shortcut.
And because my WM has its own modifier, the shortcuts never ever clash with any other software.
Offline rm-rf
« Reply #24 on: Fri, 13 October 2017, 21:06:35 »
ratpoisonwm.
Offline JohanAR
« Reply #25 on: Mon, 16 October 2017, 05:32:07 »
I switched to Gnome Files (Nautilus) but I think I read that they fixed the Thunar crash I was having. Can't remember exactly what it was but I think something like occasional crashes when copying or moving a large number of files
Offline iLLucionist
  • Topre is Love.
« Reply #26 on: Mon, 16 October 2017, 06:55:02 »
It's old school, but I switched back to good old mc. Thunar keeps crashing for me, also in 17.04.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #27 on: Mon, 16 October 2017, 10:29:34 »
I'll stick to ranger because vi commands. These days I barely need pcmanfm or thunar (never had that crashing issue though). I've read a few things about Midnight Commander but for me to switch to mc when ranger is available; I dunno, probably not. I don't have memories fond or otherwise of mc so there it is.
Offline iLLucionist
  • Topre is Love.
« Reply #28 on: Mon, 16 October 2017, 13:42:03 »
I should give ranger a go, never really tried it. I had it installed once, but you know, never got to switching.
« Reply #29 on: Mon, 16 October 2017, 14:26:23 »
Heh. I haven't used a regular file manager in a long time. The files I manage the most are images, for which I use geeqie (a fork or clone of gqview, I dunno which) and it is good enough for image files. Reminds me of ACDsee that I used to use on Windows in the '90s.
Back in the late '90s, I contributed graphics and some code to gentoo -- which is a file manager, at least a year older than the Linux distribution with the same name.
« Reply #30 on: Wed, 18 October 2017, 21:55:36 »
This thread prompted me, at last, to add the "useless gaps" in my Awesome WM.
The main reason I need to lose some screen real-estate by adding useless gaps between a tiling manager's windows is because otherwise sometimes it can be hard to see which window ends where and which starts where: for example if I've got two terminal containing logs it can get really confusing.
Now it's funny because Awesome WM does add useless gaps even at the outter edge of the screen, which doesn't make any sense to me (no risk of mistaking the border of the monitor for anything!). They also said they added useless gaps "in the name of art and unicorns", something like that: so basically that and also adding gaps at the outter edge shows they don't really simply don't get why some people like both tiling managers and "(not so-)useless gaps".
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #31 on: Wed, 18 October 2017, 22:39:52 »
I tried gaps for a while but thought it was kind of wasteful; sexy unixporn though. Suppose if you have enough screen real estate it doesn't really matter.
Offline JohanAR
« Reply #32 on: Thu, 19 October 2017, 01:24:35 »
You can increase the border width and tweak the colors of active/inactive windows in i3, unless you like the aesthetics of gaps. The default settings are fine for me though
« Reply #33 on: Fri, 20 October 2017, 21:49:21 »
I just explained I had sometimes troubles determining to which terminal window certain log lines where belonging to when I had terminal window stacked on each other and displaying logs and you call it "unixporn" : )
I didn't "try it": I set it up to solve a practical issue I had (basically "readability" in certain cases).
But it's true that it's damn good looking unixporn too  :thumb:
Offline iLLucionist
  • Topre is Love.
« Reply #34 on: Sat, 21 October 2017, 16:17:02 »
My screen estate is precious, tried gaps but I could cram in 3-4 more lines vertically of code. So meh... no gaps for me.
« Reply #35 on: Sat, 21 October 2017, 18:36:42 »
I should really "Use the source, Luke!" and go modify the code of that tiling WM myself: my main "IDE" (well, Emacs) is typically using all the vertical height of the screen (besides the tiny "taskbar", but with a shortcut you can make the "taskbar" go away), so the only reason I'm wasting real-estate there is because the gap in Awesome WM also adds gaps at the "outter edges".
If it only added "useless gaps" between windows and not at the outter edge, I'd get both readability between my terminal windows and all the vertical height for Emacs.
Offline berkiyo
  • y=mx+c
« Reply #36 on: Sat, 21 October 2017, 19:13:46 »
I really liked i3wm and especially for i3-gaps just for the eyecandy. However, I found that it was more hassle than it was worth so I went back to Xfce and instead just use tmux for a tiling terminal in xfce4-terminal.
"With great power comes great responsibility."
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #37 on: Sun, 22 October 2017, 03:24:54 »
A few hours later--learned how to save/autostart one 'workspace' layout. Very rewarding this tiling window manager is. So naughty with your unixp.. err i3-gaps btw  ^-^
Offline iLLucionist
  • Topre is Love.
« Reply #38 on: Sun, 22 October 2017, 16:43:56 »
I even tried to not have titlebars for my panes in i3, but that was too much. Sometimes I look at them. I also used evilwm for a looooong time.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #39 on: Sun, 22 October 2017, 17:01:38 »
Total hobbiest at this point with my Manjaro with 2 pixel borders and no visual titlebars. Hidding titlebars was something I was constantly trying to do in all the popular desktop environments of debian, opensuse, ubuntu, and windows. Maybe my roguishness will change who knows.
« Reply #40 on: Sun, 22 October 2017, 18:12:04 »
Re guys,
so I did it yesterday: decided to dig into the source and modify it myself. Long story short: my distro had, by default, Awesome 4.0.1 while 4.2 had a, non integrated, pull request, to do "less useless gaps" the exact way I wanted them.  I didn't want to install 4.2 (didn't want to redo my config now: not too sure if there were incompatible changes or not) nor mess with merging that pull request, so I adapted the code for my 4.0.1 setup and now I've got the exact behavior I wanted...
1 pixel-wide borders for every window, no titlebars, a taskbar at the top of the screen that I can remove and/or bring back with a shortcut, and... Useless gaps but only between windows: no pixels lost at the "edges" of the monitor anymore. Also in Awesome WM there's a shortcut where you can resize the number of pixels of the useless gaps in real-time.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #41 on: Sun, 22 October 2017, 18:18:55 »
Re guys,
Sounds like a job well done :)
Offline iLLucionist
  • Topre is Love.
« Reply #42 on: Mon, 23 October 2017, 04:39:02 »
Re guys,
Here, take my respect.  :cool:
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #43 on: Tue, 07 November 2017, 12:29:52 »
Trying out the gaps. You know, it's not that bad. Still plenty of room (although more rez monitor wouldn't hurt)
181766-0
Offline tristinDLC
« Reply #44 on: Thu, 09 November 2017, 01:53:40 »
I bit of a late quote, but I use Magnet on all my Macs and love it. It's also great if you ever use a dock and external monitor while still needing to take your Mac with you at times. It will let you quickly resize all your windows back to the laptops screen size instead of running off the edge because your external monitor has more real estate to work with. I use Magnet throughout the day switching stuff around and the shortcuts are great. I just checked and it's currently on sale in the App Store.
Offline _rubik
« Reply #45 on: Fri, 10 November 2017, 22:43:49 »
i3 ride or die. It fills every requirement I can ask for and more. Its tiling, lightweight, customizable, open source, distro-flexable, and with a very active and supportive user base. Not to mention that it comes in a few different flavors and integrates well with X configs. I'll have to post a few scrots when I'm back on my main machine.
Offline os
    • trash site, don't come here
« Reply #46 on: Thu, 04 January 2018, 11:10:14 »
A long time ago I switched from XFCE to i3wm, just loving it.
On my Thinkpad I only have a single 1440p screen but still, I love how I do not have to use a mouse and can precisely and predictively navigate windows.
I always enjoy looking at other people's dotfiles, so here are mine: github.com/os-sc/dotfiles
Offline bearz42
« Reply #47 on: Sat, 24 February 2018, 17:59:18 »
Here are my dot files that I'm using http://dotshare.it/~bearz42/
I had switched to another color scheme but I just keep coming back to this one.
Offline iLLucionist
  • Topre is Love.
« Reply #48 on: Wed, 07 March 2018, 14:36:18 »
I'm still on i3. This week, I switched to emacs (with evil-mode, sit down and chill) and it interferes with alt-key. Blegh... remapped alt to super (mod4) for i3. HATE IT.. winkey is very small on 87u (1x)
Offline sth
« Reply #49 on: Thu, 08 March 2018, 17:32:18 »
why not swap mod4 and alt with xmodmap? https://unix.stackexchange.com/questions/86933/swap-alt-and-super
