Author Topic: Happy hacking pro 2 rubber came off  (Read 2198 times)
Offline Ultimatemind
« on: Sun, 08 October 2017, 14:21:01 »
Hello,
Has anyone ever had this happen to their HHKP2 where the bottom rubber came off or have any idea how to replace that? I'll take any suggestion!
Thanks
Offline CaptainVinceO2
    • ApexKeyboards
Re: Happy hacking pro 2 rubber came off
« Reply #1 on: Sun, 08 October 2017, 15:10:50 »
The rubber feet? You could buy some good bumpons at a hardware store, hobby electronics store or Amazon. My recommendation the 3M bumpons are really good compared to regular furniture ones.
Sent from my Nexus 5 using Tapatalk
« Reply #2 on: Sun, 08 October 2017, 15:40:45 »
Yeah the rubber feet. 3M seems promising.
« Reply #3 on: Tue, 02 January 2018, 22:00:00 »
Or you could get a rubber mat (or a folded sheet of draw liner) to go underneath, perhaps even affixed with double-sided tape.
