Author Topic: 10 Blank Keycaps (blue) - Cherry? $3.50 BIN  (Read 4182 times)
Offline nowsharing
  • Swoop
« on: Wed, 17 March 2010, 15:54:13 »
I came across this auction for 10 blue blank keycaps:
http://cgi.ebay.com/KEYBOARD-TYPE-SWITCH-PUSH-BUTTONS-Qty-10_W0QQitemZ370212888590
No idea what board they're from, but I'm sure that someone here does.
Offline mrbill
    • http://weblog.mrbill.net
« Reply #1 on: Wed, 17 March 2010, 16:15:56 »
Just bought both sets, hopefully they'll fit on my Cherry boards.
Keyboards:
IBM Model Ms: 51G8572 (\'94, \'96), 1391401 (\'90), 1369050 (\'95, Dell), 1394946 (\'89 Industrial)
Unicomp Model Ms:  Customizer 104, SpaceSaver 104
Chicony: KB-5181, KB-5191
Cherry:  MX11800 (x2), G86-6241 "Ricercar SPOS"
Filco: FKBN87M/EB x2, Cherry Browns
Sold: Matias Tactile Pro 1.0 (x2), Kensington Studioboard Mechanical, Scorpius M10, AEK II (x2), Compaq 11900 (x2), IBM Model F (AT), Filco FKB104MC/EB
Available Free for Cost of Shipping: ABS M1, Solidtek KB-6600ABU, KeyTronic KB101Plus
Offline EverythingIBM
« Reply #2 on: Wed, 17 March 2010, 22:57:05 »
Quote from: ripster;164906
Maybe.  The stems  look too big for a Cherry MX switch.  They fit the switch but when you push down nothing happens.
If it doesn't fit or work, you MAKE it! A little duck tape, some glue, a screw driver, and a file.
Offline Nonmouse
« Reply #3 on: Wed, 17 March 2010, 23:24:45 »
Quote from: EverythingIBM;165028
Screw that.  Whadda think god made Bic lighters for?
Offline ricercar
  • mostly abides
« Reply #4 on: Sat, 20 March 2010, 18:46:12 »
Relisted.
Make sure you tell us when they arrive how well they fit on Cherry switches!
Two sayings I once knew in Latin:
  • There's no problem so great it can't be solved with duct tape and needle nose pliers.
  • Don't force it; get a bigger hammer.
Offline pfink
« Reply #5 on: Sun, 21 March 2010, 10:28:41 »
Quote from: ricercar;165733
Relisted.
I got some of these in the mail yesterday. They don't fit Cherry switches, the stem is too wide.
Offline sethstorm
« Reply #6 on: Sun, 21 March 2010, 20:18:50 »
Quote from: pfink;165861
Then by all means cut the keytop to fit the stem.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline ricercar
  • mostly abides
« Reply #7 on: Sun, 21 March 2010, 21:06:11 »
THANK YOU KINDLY. I really don't need to spend $10.
