Author Topic: Filco 87U USB device error  (Read 2208 times)
Offline trievalot
« on: Thu, 18 March 2010, 07:04:47 »
my 87 filco doesnt work every morning!!!
i have to restart my notebook sometimes 2-3 times and plug in and unplug the keyboard multiple times.
the numpad and trackball work fine, but the keyboard will light up for a couple seconds (caps and scroll) and then nothing.
ive removed the USB devices and readded, and turned off power managment.
the notebook is a HP NX7400 running XP. all original software and drivers.
has anyone else had these issues?
its a bit hit and miss, but to get working, i power off, take battery out, put in, power on and boot with nothing connected. i then plug keyboard in 1st and let all drivers intall (it will find a USB keyboard if i do this) the connect numpad and trackball.
ive tried the keyboard on other peoples machines and its worked everytime except once (removed and replug fixed it)
do i have a faulty board, or POS computer???
[SIGPIC]
Offline itlnstln
« Reply #1 on: Thu, 18 March 2010, 07:22:50 »
Sounds like your computer if you don't have problems using it on another PC.  I wouldn't know where to start, though.  It could be something with the USB contoller, the ports themselves, a BIOS problem, etc.
Offline Rajagra
« Reply #2 on: Thu, 18 March 2010, 07:23:04 »
Do you have a powered USB hub you can use for testing? If it connects through that reliably then your laptop USB ports probably can't supply enough power.
Offline Mental Hobbit
« Reply #3 on: Thu, 18 March 2010, 07:26:36 »
Have you tried to connect the Filco only, without trackball and numpad? Maybe three devices draw more power than your laptop's USB can handle?
Edit: I'm too slow.
Typing on blues.
Offline kriminal
« Reply #4 on: Thu, 18 March 2010, 07:28:33 »
one thing's for sure the issue resides with your laptop. powered usb hub seems like a good option.
« Last Edit: Thu, 18 March 2010, 07:44:38 by kriminal »
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline trievalot
« Reply #5 on: Fri, 19 March 2010, 02:05:25 »
did a fuoll chkdks today to no avail
weird thing....i used a USB to PS2 convertor, then a PS2 to USB adapter and the damn thing works.
Pretty sure i need a new lappy.
[SIGPIC]
