Author Topic: Help !  (Read 3374 times)
Offline burann
Help !
« on: Sun, 15 October 2017, 04:01:49 »
Hi,
I'm working on restoring a Swedish built computer from the early 80's and the keyboard have been quite a challenge, its a Keytronic design (A65-02486) with foam and foil switches.
I've located a supplier for new foam, so that problem is solved, however, I'm trying to locate keycaps that fits and hope you guys can help identifying any  compatible keycaps (if there is any).
Model number on board:
https://www.dropbox.com/s/ervcq4uzf1fazlc/2017-10-07%2016.31.01.jpg?dl=0
Keycap photos:
https://www.dropbox.com/s/iefjblrkp8afeny/2017-10-15%2010.54.45.jpg?dl=0
https://www.dropbox.com/s/0i0oetrfx129gro/2017-10-15%2010.54.52.jpg?dl=0
Thanks in advance !
Offline Perfex
Re: Help !
« Reply #1 on: Sun, 15 October 2017, 15:59:45 »
Offline burann
Re: Help !
« Reply #2 on: Wed, 18 October 2017, 14:10:59 »
Thanks, I know about that site/page, no closer to solving the problem, if its possible at all.
