Author Topic: Filco Spacebar Switch Exchange  (Read 87362 times)
Offline skcheng
    • Tenafly Dentistry
« on: Thu, 18 March 2010, 10:08:20 »
What cherry switch would be ideal for a Filco spacebar since it needs to be replaced?  The board is a cherry blue board that I just purchased from Dcozart.    White?  Brown?  Just replace it with a blue?
Also, does anyone have a link to Filco switch replacement??  I found a link to opening up the Filco case by Rip, but not one specifically for soldering in a Filco switch.
Thanks!!
skc
Offline nanu
    • http://T-T.be/portal
« Reply #1 on: Thu, 18 March 2010, 10:15:43 »
I don't think you can easily replace or modify Filco's plate-mounted Cherry MX switches.  I'm under the impression that because they're all plate-mounted, you have to desolder all switches just to access one.
Offline skcheng
    • Tenafly Dentistry
« Reply #2 on: Thu, 18 March 2010, 10:25:58 »
Quote from: nanu;165121
I've been in touch with Brian over at Elite and this is what he had to say:
The frame on the 87key FILCOs has a tighter fit than the 104keys but
both can be opened relatively painlessly using a dull butter knife after
you've removed the screws on the back of the keyboard (1 screw on the
back of 87key and 3 screws on the back of 104key boards). Once you get
the board open your soldering/desoldering skill will come into play.
Note that the 87key boards have 2 small screws below the F1-F12 keys
that must be removed to access the back of the PCB.
Good luck!
I like the good luck part.   I'm fairly certain that Ripster along with others here have swapped out Filco switches.
So, what would be the perfect switch for a space bar??
skc
Offline skcheng
    • Tenafly Dentistry
« Reply #3 on: Thu, 18 March 2010, 10:31:14 »
Quote from: ripster;165126
Look at the "Kinesis Keypad Cherry Key Swap" mod in the Mods section of the forum for how to swap keys.
Personally I like the Cherry blue for  spacebar in Cherry blue keyboards.  The Cherry Clear spacebar for Cherry brown keyboards.
Thanks Rip.  I'll check that out.  While I'm swapping out the switch, I'll swap out the majority of the keys for double shots.   I bought 3 keyboards for the appropriate keys LOL.   And it looks like I'll probably keep the bottom row standard like you did.
skc
Offline nanu
« Reply #4 on: Thu, 18 March 2010, 20:12:37 »
It makes sense to me now.
In the absence of a mounting plate the PCB-mounted MX switch has a pair of fixation pins, one to either side of the switchpost at the bottom center, to ensure a proper alignment for soldering.  The restriction imposed by a mounting plate is that you cannot open up a switch while it's still soldered in place, because the 4 clips on the sides are blocked by the plate, but indeed the mounting plate still only serves to align switches.  Switches are removed from above the plate.
« Last Edit: Thu, 18 March 2010, 20:15:20 by nanu »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Thu, 18 March 2010, 21:50:04 »
I'm on a horse.
Relevance? None.
kishy.ca
Offline elservo
« Reply #6 on: Fri, 19 March 2010, 00:32:16 »
I can't believe Canada decided to move away from the red Mountie coats.  Big mistake if you ask me.
Majestouch Tactile Click (Work)
AEKII(Home)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Fri, 19 March 2010, 11:48:23 »
Since when?!?
I can deal with the coats I guess...but the hats stay.
(you may know what I'm talking about)
I've only seen an RCMP officer in full dress uniform once. For the most part they drive around in lame-ass Chevy Impalas (sorry if you have an Impala, anyone, but that is not a police car...nothing FWD belongs in a police fleet) and wear whatever the brown uniform is called in my area.
« Last Edit: Fri, 19 March 2010, 11:50:34 by kishy »
kishy.ca
Offline trievalot
« Reply #8 on: Sat, 20 March 2010, 06:55:14 »
[SIGPIC]
Offline EverythingIBM
« Reply #9 on: Sun, 21 March 2010, 03:07:59 »
Quote from: kishy;165416
Since when?!?
I've never seen an RCMP officer before. I do know someone who works at an RCMP office though, but, just standard business clothes. They threw out all of the IBM model Ms they were using because to get "new" keyboards (still like the RCMP?).
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Sun, 21 March 2010, 11:30:18 »
I think the presence of RCMP in my city (which has its own police force + local provincial police presence) relates to North America's most significant border crossings being here.
The Americans got mad that we were being friendly.
Filco switch swaps to RCMP? This is a new one...
kishy.ca
Offline skcheng
    • Tenafly Dentistry
« Reply #11 on: Tue, 23 March 2010, 11:15:22 »
Not to derail the current Canadian discussion, but I finally found some time to remove the broken space bar switch.  Just like Rip described, remove 2 solder connections and the switch pops right out.  I just had to take the switch apart to see why it's broken and this is what I found:
So, what do you think caused this??  Switch is totally corroded?
skc
Offline Mental Hobbit
« Reply #12 on: Tue, 23 March 2010, 13:44:18 »
I don't see how gold plated contacts could corrode like that. Either Cherry's QC has completely gone down the drain, or Costar uses counterfeit switches.
Typing on blues.
Offline itlnstln
« Reply #13 on: Tue, 23 March 2010, 13:47:30 »
Yeah, I kinda thought that was the point of using gold on the contacts.  That might be why some people have experienced switch bounce (chattering) in their older Filcos.
Offline kriminal
« Reply #14 on: Tue, 23 March 2010, 13:54:08 »
this is not good news
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline itlnstln
« Reply #15 on: Tue, 23 March 2010, 13:55:46 »
The instances of chatter are pretty few and far between but something to be aware of.
I wish I could see the pics, though. They are getting blocked here at work.
« Reply #16 on: Tue, 23 March 2010, 14:07:09 »
@skcheng: Would you please upload some photos at high resolution?
Typing on blues.
Offline skcheng
    • Tenafly Dentistry
« Reply #17 on: Tue, 23 March 2010, 15:39:41 »
Quote from: Mental Hobbit;166362
Here you go Mental:
Offline skcheng
    • Tenafly Dentistry
« Reply #18 on: Tue, 23 March 2010, 15:47:30 »
Quote from: Mental Hobbit;166351
I was just thinking that maybe something was spilled onto the switch??   I checked the keyboard and the rest of the switches appear to work fine??  That almost looks like battery acid on the contacts?
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #19 on: Tue, 23 March 2010, 19:39:14 »
Water can cause that kind of corrosion/oxidation, but more likely a juice drink (perhaps citrus) would cause something like that. One would think soda pop would do that but soda pop can be used to clean copper.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #20 on: Tue, 23 March 2010, 19:55:04 »
It's green...like the way copper corrodes.
It does look a bit like battery acid though, like the remnants of those old barrel-shaped CMOS batteries on really old motherboards.
kishy.ca
Offline elbowglue
« Reply #21 on: Wed, 24 March 2010, 02:23:11 »
For gods sakes man, can someone with a background in metallurgy tell me what is going on here?  Does this mean the Gold crosspoint MX switch on the filco is Copper and predisposed to corrosion?
Anyone?  Ripster, you used to be a metalluragist right?
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline clickclack
« Reply #22 on: Wed, 24 March 2010, 02:45:28 »
Quote from: elbowglue;166465
This is simple corrosion/oxidation, perhaps advanced at somepoint by some spillage. The gold crosspoint technology refers to the very tiny vertical and horizontal contacts on those copper leaf contacts. The very tips of them seem to be gold plated. On the older (but current style) cherry switches there seems to be either a higher propensity to corrode but this could be due to a variety of reasons, different alloy, purity, factory oils, age, plating... and so on. I am not sure however if the older cherry switches have the gold contacts or if they have just worn so much that you cant tell anymore.
In all  honesty I wouldn't worry too much, if at all.
Offline clickclack
« Reply #23 on: Wed, 24 March 2010, 02:55:04 »
I was just looking at the pics again and noticed that the two copper contacts are not making contact! If they have been bent out of the way to somehow illustrate the problem then nevermind. If however they are not bent out of the way on purpose then that would most certainly cause a problem. Just take a pair of pliers or tweezers or toothpics... and bend it back. I just figure I should point that out just in case it was not on purpose, if it was then...umm.... just kidding =P
Offline skcheng
    • Tenafly Dentistry
« Reply #24 on: Wed, 24 March 2010, 07:48:24 »
Quote from: clickclack;166467
This was my first attempt at removing a switch from a Filco board and I sort of just ripped it out.   And they I used needle nose pliers to take the switch apart.    So I probably bent the contacts inadvertently.
Still......that's a LOT of corrosion on a "newish" switch.   And I'm assuming a liquid spill of some kind??   I don't want to believe that the switch would just oxidize like that after only a short time in operation??
« Reply #25 on: Wed, 24 March 2010, 08:09:45 »
Doczart mentioned the broken switch in his sales ad. Did you ask him if anything unusual happened to that board? Guess you don't feel like desoldering and opening another working switch to see if there are any signs of corrosion too?
Typing on blues.
Offline skcheng
    • Tenafly Dentistry
« Reply #26 on: Wed, 24 March 2010, 08:21:00 »
Quote from: Mental Hobbit;166493
I bought a bunch of switches from DigiKey so I might take a few of the other switches out to inspect.   Not difficult to do.  I should probably make a tool to remove these switches to make removal easier.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #27 on: Wed, 24 March 2010, 08:31:49 »
I just had a really dumb idea.
Solder in a white Alps switch instead :D
(in case it's not obvious, I realize how impractical this is)
kishy.ca
Offline skcheng
    • Tenafly Dentistry
« Reply #28 on: Wed, 24 March 2010, 09:09:23 »
Quote from: kishy;166500
I'm new here.......and quite impressionable  :smile:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #29 on: Wed, 24 March 2010, 11:12:21 »
Quote from: skcheng;166513
Well...what can I say? Don't listen to me lol.
kishy.ca
Offline skcheng
    • Tenafly Dentistry
« Reply #30 on: Wed, 24 March 2010, 13:16:37 »
Switch swapped out and two solder dots and I'm up and running.   Really not that bad.   And I'm happy it was only one faulty switch.   Just tested everything again and all is well.   If I can swap out a switch, anyone can.
Offline skcheng
    • Tenafly Dentistry
« Reply #31 on: Thu, 25 March 2010, 00:47:42 »
Quote from: ripster;166674
After extensive RS MIZAR M24 testing I've determined....................................................................
You really don't want to know.
A shame really.  That rug really tied the room together.
But Rip, I licked the broken switch and it didn't taste of urine???    :tongue1:
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #32 on: Thu, 20 May 2010, 08:51:43 »
Yeah, looks like copper oxidation...
Regarding the quality control thing:
There is no flawless QC! Look at NASA and airlines, I guess they have some very strict QC...
Still, there are exploding rockets, space-shuttles, death-stars, and even snakes on a plane :P
A Ghost From The Past
Offline skcheng
    • Tenafly Dentistry
« Reply #33 on: Thu, 20 May 2010, 09:11:14 »
Quote from: TheSoulhunter;184644
Yeah, but none of that compares to the stress of a non-functioning cherry switch  :)
Offline JBert
« Reply #34 on: Thu, 20 May 2010, 14:15:27 »
It used to be different. Read Feynman's observations on the reliability of the space shuttle for more details.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ricercar
  • mostly abides
« Reply #35 on: Thu, 20 May 2010, 15:11:46 »
Quote from: JBert;184885
Feynman breaks his own Feynman-Tufte principle:  A visual display of data should be simple enough to fit on the side of a van. That page is too dense.
Offline JBert
« Reply #36 on: Thu, 20 May 2010, 16:10:39 »
He ain't going to fix it, that's for sure.
The storage list:
[/SIZE]
Offline maxlugar
« Reply #37 on: Thu, 20 May 2010, 18:03:09 »
Quote from: skcheng;166675
You people are just not right  :)
Emperor of the IBM 84-key AT Model F Darkside
