Author Topic: I need help  (Read 2315 times)
Offline kolec94
I need help
« on: Fri, 20 October 2017, 09:01:11 »
I bought a Collermaster keytester pcb and I don't know how to program it
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1709
kbparadise v60 blues
Offline mogo
Re: I need help
« Reply #1 on: Fri, 20 October 2017, 09:07:40 »
https://geekhack.org/index.php?topic=87964.msg2396291#msg2396291
There's an atreus guide, but you should be able to use it as a general guide for flashing your teensy. Forum searching is your friend.
Offline kolec94
Re: I need help
« Reply #2 on: Fri, 20 October 2017, 09:15:28 »
now will I be able to flash this to the teensy and have it work?
