Author Topic: high sierra keyboard soft ware  (Read 8112 times)
Offline hotrattz
« on: Fri, 20 October 2017, 13:13:51 »
so i'm sure there's a thread somewhere ?
what should i use for my leopold fc750 need to swap option/ command and be able to do some macros like cut copy paste and karabiner elements isn't all that great anymore what is everyone using ?
Re: high sierra keyboard soft ware
« Reply #1 on: Fri, 20 October 2017, 21:45:05 »
On Sierra (and previous versions) I just use System Preferences - Keyboard to swap the Cmd/Opt modifier keys around.  Need to do it once for each keyboard I plug in.
Karabiner (formerly KeyRemap4MacBook) is the best keymapper for macOS I have heard of, but not needing macros I have never used it.
Offline tristinDLC
« Reply #2 on: Thu, 09 November 2017, 05:37:21 »
For Mac, you want Karabiner Elements.
If you want to run macros, you can use KE to add rules via the Complex Modifications menus, which have some key combos already created and you can load them up from a GH repo. If your desired macro isn't there, then you want to use Automator to run an Applescript that has your actions programmed into it. You can then set that process up to run via assigning it to a hotkey in System Preferences.
