Author Topic: PS2 to USB adapter challenge  (Read 12107 times)
Offline elbowglue
« on: Fri, 19 March 2010, 12:02:15 »
The problem:  I have a number of PS2 keyboards, when I hook them up to my computer via PS2 to USB adapter, they often work with one big problem.  You can probably replicate this problem yourself as well.
Use this website to record which keys are registered:
http://random.xem.us/rollover.html
Hold down W.  Keep it held down the whole time.
Hit D.  Let go of D.  Continue holding down W.
(this is a test to see if in a first person shooter you can run forwards, strafe to the right, then keep running forwards)
If you use a PS2 to USB adapter, the W will stop registering after you let go of D.  If you are using direct connection into PS2 port, or if you are using direct connection into USB port you will have no problem at all, it will continue to register the W.
I have tried these two USB to PS2 adapters, both of them have the problem:
Second one vendor id is Vid_13ba
Does anyone know of a Ps2 to USB adapter that works correctly in this fashion?
« Last Edit: Tue, 23 March 2010, 16:56:35 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Rajagra
« Reply #1 on: Fri, 19 March 2010, 12:15:46 »
The bluecube passes this test.
Offline elbowglue
« Reply #2 on: Fri, 19 March 2010, 12:21:08 »
I guess this challenge wasn't so challenging.  :P  Thanks raj.
Anyone got this adapter, able to do the challenge on it?
http://www.amazon.com/Ps-Keyboard-Mouse-Usb-Adapter/dp/B000G7WYZG/ref=sr_1_3?ie=UTF8&s=electronics&qid=1269019146&sr=8-3
Offline ch_123
« Reply #3 on: Fri, 19 March 2010, 12:46:34 »
The Belkin also works properly.
Offline Viett
« Reply #4 on: Fri, 19 March 2010, 13:53:24 »
I've run into that same problem with this adapter (13ba):
and this adapter (also 13ba):
This last adapter I purchased at a computer store, and I actually convinced the salesman to let me try it before I bought it, and it works great (0e8f):
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline TexasFlood
« Reply #5 on: Fri, 19 March 2010, 14:15:27 »
My old APC failed this test and fails some other aspects like scroll lock not working.  And it's my best one, :sad:, because the others I bought at Microcenter way back "forget" that keys like shift of control are being held down after a few seconds.  Maybe time for some new adapters.
Offline JBert
« Reply #6 on: Fri, 19 March 2010, 14:47:36 »
Quote from: ch_123;165430
Indeed.
It only has 6KRO, of course.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline Viett
« Reply #7 on: Fri, 19 March 2010, 15:03:13 »
Quote from: TexasFlood;165446
... the others I bought at Microcenter way back "forget" that keys like shift of control are being held down after a few seconds.
I also had that problem with the two bad adapters I listed above. The adapter would eventually forget if you were holding down one of the "lock" keys after about a second, which was annoying because I used Caps Lock as my talk key in games.
Offline ricercar
  • mostly abides
« Reply #8 on: Sat, 20 March 2010, 19:47:35 »
This one has a funky keyboard behavior, but the pointing device (green) PS/2 handles everything I've given it (trackpad, trackpoint, trackball, mouse, etc)
Offline Viett
« Reply #9 on: Sat, 20 March 2010, 19:57:02 »
I love the USB hub and the fact that it takes USB mini-B. That's all I use it for nowadays. Sometimes, I ironically plug a good PS/2 to USB adapter into it.
Offline phobus
« Reply #10 on: Wed, 24 March 2010, 05:50:14 »
I have an adapter that looks exactly this, aside from color:
http://geekhack.org/attachment.php?attachmentid=2871&d=1245964845
  Product ID:   0x0240
  Vendor ID:   0x0711  (Magic Control Technology Corp.)
It passes your test with my Model M attached, although there are some other combinations that do not work. As Ripster pointed out, though, the keyboard is probably to blame there.
Offline elbowglue
« Reply #11 on: Fri, 02 April 2010, 11:24:26 »
This one works:
VID 0E8F - Passes the test.  Got this off of ebay from some hong kong seller.  The build of it sucked (the blue casing popped off after I plugged it in once).  But electronially it works great, I had to tape the plastic closed so it looks a little ghetto.
HID\VID_0E8F&PID_0020&MI_00\7&14238B5&0&0000
Offline elbowglue
« Reply #12 on: Mon, 10 May 2010, 02:26:12 »
Here's an update to a long dead thread:
Here are the PS2 to USB adapters I would highly recommend:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120544070091&ssPageName=STRK:MEWNX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280454131729&ssPageName=STRK:MEWNX:IT#ht_3458wt_821
Both of these work well without any flaws that I could find.  They all work with my M13, also my Compaq MX 11800.
The build on the first one (Y shaped one) is much much better, the blue triangle USB adapter fell apart quickly.
Thanks viett.
Offline Megaweapon
« Reply #13 on: Mon, 10 May 2010, 10:12:50 »
For $2 shipped I'll gamble.
That said, I only use my Model M at the Linux console (which I only need to use infrequently) so it doesn't get much of a workout.
While I'm pimping this keyboard:  Anyone got a cheap source for the green (?) Model M TrackPoint tips?
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline Viett
« Reply #14 on: Mon, 10 May 2010, 10:13:18 »
Quote from: elbowglue;180606
Thanks viett.
The blue cube has met its match ;).
Offline Megaweapon
« Reply #15 on: Mon, 10 May 2010, 10:30:52 »
Too bad daily-favorites won't sell to you unless you have PayPal.  :tsk:
• Rosewill RK-9000I
Offline erricrice
« Reply #16 on: Mon, 10 May 2010, 10:36:30 »
Quote from: ripster;180686
Does it work with OSX and Linux?
I second that, has anyone tested them on OSX or linux?
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Mañana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline Viett
« Reply #17 on: Mon, 10 May 2010, 13:19:01 »
I own another 0E8F (not one of the two elbowglue recommends) and it works fine on Linux and Mac OS X.
Offline elbowglue
« Reply #18 on: Mon, 10 May 2010, 13:44:35 »
Does it work with Win7, OSX and Linux?
Haven't tried sorry :( Don't have access to win7 osx or linux systems easily... :( What can I say I'm a windows fanboy? :P
Offline erricrice
« Reply #19 on: Mon, 10 May 2010, 13:53:49 »
Quote from: Viett;180764
Do you happen to have a link for one on ebay or something?  I just need one for work that functions on a MAC for sure
Logitech G5[/FONT]
Offline Viett
« Reply #20 on: Mon, 10 May 2010, 14:02:48 »
Quote from: Viett;180766
It does not recognize the keyboard on boot? I have an eMac and also have this problem with adapters. It has to be a power issue, because a regular USB keyboard works fine.
Last time I checked, an adapted PS/2 keyboard is indistinguishable from a USB one other than the amount of power used.
Once you're booted up, the adapted keyboard should work fine.
To quote myself from another thread, I believe your problem lies elsewhere. I don't own a single adapter that my eMac recognizes on boot, but they all work after it's booted up.
Offline vils
« Reply #21 on: Mon, 10 May 2010, 14:26:20 »
I got this one:
Bought two for $8, shipping included.
I´ve had som issues with it, some key combinations will cause the KB to stop functioning and I have to restart the comp in order to get it working again.
This is with my SMK-85 and running Win7, 64-bit. I´ll try to get a Blue cube and see if its better.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline erricrice
« Reply #22 on: Mon, 10 May 2010, 14:35:34 »
Quote from: Viett;180778
Yeah sorry, I posted here before I read the update in the other thread.
Logitech G5[/FONT]
Offline ch_123
« Reply #23 on: Mon, 10 May 2010, 14:40:06 »
A G4 Power Mac I found once wouldn't work with my HHKB when it was booting (for accessing the Open Firmware), but the Filco would work just fine.
Offline aegrotatio
« Reply #24 on: Wed, 12 May 2010, 12:57:26 »
This one works for the OP's challenge but fails wexc and rtyu with a Model M (not sure if it's the keyboard or the adapter).  The adapter ID is 0x0D3D.
http://www.amazon.com/gp/product/B00008V9EF/ref=oss_product
The old 10-year-old model and the one I just bought (with thinner cable) are the same.
By the way, there are at least two kinds of USB keyboard modes, USBHID and a nightmare named USBHIDBP (and I'm not talking about another horror, OHCI vs. UHCI).  In the past this was a bitter pain in the neck with Linux and lousy KVMs.  Older BIOSes would turn on the keyboard as a USBHIDBP and it would stay that way after the system started up, causing pain and suffering and missed keystrokes and multimedia keys that don't work.  Another symptom is the USB keyboard doesn't work until the system starts up.  Yucky generic PS/2-to-USB converters have re-awakened this terror.
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline chucknobucks
« Reply #25 on: Sun, 05 September 2010, 22:54:30 »
My favorite keyboards are my two compact MiniTouch KB1948 PS2 models. Had the same problems and some more I can't remember. Tried many of the PS2 to USB adapters listed here with little or no success. Finally found a product called Y-mouse. No more problems with my gaming tower or my laptop.
http://www.piengineering.com/ymouse/whym271.php
Shop around and watch eBay. Also take care that you don't buy one of the many other similar products that piengineering makes. They all look similar and if there is no photo + description it can get kind of confusing.
