Author Topic: [IC]KBDfans75 v2 PCB new design  (Read 40828 times)
Offline Trousers
Re: [IC]KBDfans75 v2 PCB new design
« Reply #50 on: Sat, 11 November 2017, 14:10:47 »
I wasn't quite sure of this, but the prototype changed my mind. If the price is in any way reasonable, I think I'll get one.
Offline HotRoderX
« Reply #51 on: Sat, 11 November 2017, 16:32:27 »
The way it sounds be the same price as Gen 1's are maybe a bit cheaper? I am hopping it stays in that 170ish area.. cause its cheap enough to be reasonable but high enough quality to be more expensive.. hope that makes since.
Offline KaosJ
« Reply #52 on: Sun, 12 November 2017, 08:51:25 »
I hope cheaper, this case should be cheaper to produce afterall
Offline _rubik
« Reply #53 on: Sun, 12 November 2017, 10:08:47 »
So what's the deal with the '< >' in that layout? That is just a red flag to me.
Offline Atredl
« Reply #54 on: Sun, 12 November 2017, 13:43:09 »
It's one of the optional layouts. If you don't like that layout don't use it and build it with the regular 75% layout.
Offline _rubik
« Reply #55 on: Sun, 12 November 2017, 14:47:22 »
I must be mistaken. The render is intentionally missing the "< ," key? If so, why? Maybe I'm missing something here... Having both a command and a period is pretty necessary  :p.
Offline HotRoderX
« Reply #56 on: Sun, 12 November 2017, 15:27:17 »
The render is showing a optional layout with it adding in a number pad. It can still be built like a normal 75%
Edited for formating
Offline _rubik
« Reply #57 on: Sun, 12 November 2017, 22:28:04 »
That's my bad. I didn't consider how the numpad cuts into punctuation columns. Interesting concept, but I think I'll stick with the standard 75% Thanks for the clarification.
Offline RealLaugh
« Reply #58 on: Mon, 13 November 2017, 07:00:59 »
any news when this will go on sale?
will it be group buy or from stock?
Offline japancakes
« Reply #59 on: Fri, 17 November 2017, 04:42:45 »
This is what I'm curious about as well! Holding off on other keyboards if this is reasonably close.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #60 on: Tue, 06 February 2018, 09:02:23 »
The layout is interesting, but I'd WAY rather have one like this custom "75% + 1" build: https://geekhack.org/index.php?topic=75880.0
That would be endgame for me!
Offline schoolbus
« Reply #61 on: Tue, 27 March 2018, 17:28:42 »
is this still active?
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #62 on: Wed, 28 March 2018, 09:27:56 »
I just want the 5 degree diamond case in 75% size like they teased months ago.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline japancakes
« Reply #63 on: Thu, 26 April 2018, 01:56:33 »
Has anybody out there seen an actual build of this new layout with the numpad? I'm really tempted to do a hot swappable build similar to the layout but add back ">" and "?" and get rid of the right shift completely.
Offline HotRoderX
« Reply #64 on: Thu, 26 April 2018, 02:58:02 »
I have not seen one of these built yet! I do know he recently started advertising the plates on his website for it. The only down fall is you have to remove a stand off from the case according to his guide... which to me is a bit daunting of a task.
Offline Zuology
« Reply #65 on: Thu, 26 April 2018, 07:41:43 »
Has anyone heard if there's been any further news/progress on a 75% 5-degree case or similar? He teased it sometime last year and I'm assuming the new plate layout that requires the cutting of a standoff will be addressed in future 75% case design...
Offline schoolbus
« Reply #66 on: Mon, 02 July 2018, 16:44:39 »
Bring back this case design!
