Author Topic: Interesting Idea...  (Read 2459 times)
Offline rich1051414
Interesting Idea...
« on: Sat, 21 October 2017, 13:30:40 »
So today I was hooking up a microswitch to toggle the thermostat of my AC unit on and off(external microcontroller to add some intelligent power savings), and I realized the red and black leaf spring omron microswitches actually feel REALLY good when you use one in a push button assembly. Like next level good.
Having ordered 20 of them since I couldn't just buy a single switch, I realized there is enough room, if you stagger them, to actually make a keyboard out of them, however, the fabrication of the slider would be a problem. Has anyone done this before? A quick google search returned no results of anyone crazy enough to attempt such a thing.
Offline SamirD
Re: Interesting Idea...
« Reply #1 on: Sat, 21 October 2017, 16:03:48 »
I thought someone at one point did make a keyboard out of microswitches, but I can't remember where I read about it.
Offline rich1051414
« Reply #2 on: Sat, 21 October 2017, 16:11:39 »
Well, if someone did do it, it would make a model M feel like a children's toy. I am not sure if that amount of click clacking is even remotely reasonable, but man do I want to try it :P
AH... i found something.
http://timtyler.org/keyboard/microswitch/
This Tim guy actually did it... with the same form factor of microswitches I am talking about, only his aren't the ultra satisfying clicky type. That keyboard looks every bit as ridiculous as I thought it would :D
« Last Edit: Sat, 21 October 2017, 16:22:16 by rich1051414 »
Offline _rubik
« Reply #3 on: Mon, 23 October 2017, 10:18:43 »
... that looks more like an organ than a keyboard.
Offline SamirD
« Reply #4 on: Tue, 24 October 2017, 01:29:57 »
I'm wondering if that was the guy that I saw before or someone else.  I somehow recall the site/keyboard I saw had the black omron tackle microswitches.  :-\
Offline jcoffin1981
« Reply #5 on: Wed, 25 October 2017, 19:51:58 »
Looks pretty impossible to type on.
Offline SamirD
« Reply #6 on: Wed, 25 October 2017, 23:36:03 »
I typed on two vintage typewriters today that were not power assisted--these switches would be prefect for those that typed on those machines--the throw is so long!
Offline juryduty
« Reply #7 on: Thu, 26 October 2017, 02:52:24 »
How about using a microswitch that would fit into a 14mm square plate hole... seems like that could make it less bleacher seating and more keyboard.
like these, almost same operating force as the Saia-Burgess ones:  https://www.mouser.com/ProductDetail/Honeywell/11SM1
Offline SamirD
« Reply #8 on: Thu, 26 October 2017, 03:03:16 »
I think the problem is that he left the levers in to actuate the switches vs directly connect the key to them.
