Author Topic: USB to DUAL PS/2 Adapter for $2.50 shipped  (Read 4292 times)
Offline didjamatic
« on: Fri, 19 March 2010, 16:04:41 »
Never tried it, but here it is
Offline Viett
« Reply #1 on: Fri, 19 March 2010, 16:21:55 »
I would want to hear first from another Geekhack member if it works properly or not. Some of the problems described in this thread seem to slip by most people's notice, so it's hard to tell what you've got until you actually buy it.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline mrbill
    • http://weblog.mrbill.net
« Reply #2 on: Sun, 21 March 2010, 16:45:28 »
I have six of these that arrived last week, but haven't tried them out yet.  Will report back in a couple of days.
Keyboards:
IBM Model Ms: 51G8572 (\'94, \'96), 1391401 (\'90), 1369050 (\'95, Dell), 1394946 (\'89 Industrial)
Unicomp Model Ms:  Customizer 104, SpaceSaver 104
Chicony: KB-5181, KB-5191
Cherry:  MX11800 (x2), G86-6241 "Ricercar SPOS"
Filco: FKBN87M/EB x2, Cherry Browns
Sold: Matias Tactile Pro 1.0 (x2), Kensington Studioboard Mechanical, Scorpius M10, AEK II (x2), Compaq 11900 (x2), IBM Model F (AT), Filco FKB104MC/EB
Available Free for Cost of Shipping: ABS M1, Solidtek KB-6600ABU, KeyTronic KB101Plus
Offline Phaedrus2129
« Reply #3 on: Tue, 23 March 2010, 14:40:28 »
I just got an adapter, an annoying $9 shipped, that was both a disappointment and a surprise.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812101117
The disappointment is that it has the issue where if you're playing a game and are holding W, then press Q or E or space it stops sending W. So I thought I'd just wasted $10.
But then I tried it with my Model M, and it works perfectly! So no problem at all there, and I can still use two keyboards.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline didjamatic
« Reply #4 on: Tue, 23 March 2010, 15:14:25 »
I ordered one of the $2.50 dual adapters, will post when I receive it.
Offline Viett
« Reply #5 on: Tue, 23 March 2010, 15:58:01 »
Quote from: Phaedrus2129;166371
Post your find to the wiki (remember to get a vendor ID). I'm curious as to why the adapter wasn't an issue with your IBM, but it was for other boards. What board did you use that you had the issue with?
« Reply #6 on: Tue, 23 March 2010, 16:18:06 »
It still has the protocol issue with the IBM; I was surprised it worked at all, as from what I've heard a great many adapters won't work the Model M at all since the M draws more power than they're designed for.
I've tried it with the two keyboards in my sig; Model M 1391401 and Cherry G84-4100PPAUS.
How do I get a vendor ID?
Anyway, the protocol issue isn't a problem when it comes to typing, so it's fine with the Model M. It just makes gaming with a keyboard through the adapter near impossible.
« Reply #7 on: Tue, 23 March 2010, 16:26:13 »
Nevermind, updated it. It's already on there as VendorID: 13ba ProductID: 0017. It's the same as in the pic but with a spiffier housing and a light on the USB port when it's active.
Offline Viett
« Reply #8 on: Tue, 23 March 2010, 16:35:46 »
Yeah. I have two 13ba adapters and both have the same issue. They all look different. It's impossible to tell which vendor made them until you test them out. I'll probably update the wiki to mention this problem once I hear back from elbowglue regarding the vendor of his bad adapters.
Offline elbowglue
« Reply #9 on: Tue, 23 March 2010, 16:54:39 »
Quote from: Viett;166421
My adaptor that was shaped like a rocket ship is this Vid_13ba pid 0017
The squid shaped one is already in the trash, it stopped working after a while.. don't know it's vid
« Last Edit: Tue, 23 March 2010, 16:58:18 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
« Reply #10 on: Tue, 23 March 2010, 16:58:26 »
Actually
PS2 to USB Converter (sold under various brands: Sabrent, Cablestar, Cables Unlimited, plus others. Also known as the Bytecc BT-2000. Several websites sell it without specifying a brand name at all.)
Yet another adapter based on the same Chesen Electronics chip.
The picture doesn't show it clearly, but the electronics are molded into the translucent gray USB connector end, and the cables have a metallic look, due to clear plastic over the foil ground shield.
Reported to have "PS/2 reset" issues (keyboard won't accept keypresses for a few seconds, LEDs flash).
Bytec-2000. That's mine. But it has the 13ba VendorID. ?????
Offline Viett
« Reply #11 on: Tue, 23 March 2010, 17:39:28 »
The rocket ship adapter is also in the wiki under a different VID. I'm not quite sure what to make of this.
