Author Topic: Keyboard feel  (Read 1950 times)
Offline bettablue
  • Geeks with a Grudge. Gotta Love'em
    • All Things DOS
Keyboard feel
« on: Wed, 25 October 2017, 19:39:28 »
I know this has been asked before, but here goes.
Besides Inicomp, what keyboard has the closest in feel and auditory to the original IBM Model M?
Also, if the recommended board has the correct feel, but misses the auditory aspect, would you recommend the same board, or would you choose a different one?
Thanks much.  Your responses will have a direct impact on the purchase I plan to make within the next 4 to 5 weeks, depending on price.
Thomas
Vintage Computer user, and collector, specializing in the IBM 5150 Personal Computer, the World\'s first REAL PC!
Keyboards - IBM Model M X 2, IBM AT X 2, IBM KB8923, Apple IIe, and Mac SE boards.
-----------------IBM Think!---------------------
Re: Keyboard feel
« Reply #1 on: Wed, 25 October 2017, 19:48:19 »
Clicky black NMB "Space Invaders" are wonderful and under-rated, but they are rather rare and hard to find.
- D Trump 2026-09-28
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Keyboard feel
« Reply #2 on: Sat, 28 October 2017, 00:21:41 »
You can try other vintage and modern keyboards.  There can be multitudes of paragraphs written about this subject, but the short answer is no in my opinion.
I'll leave it at that.
Offline ander
  • I type, therefore I am
Re: Keyboard feel
« Reply #3 on: Sat, 28 October 2017, 02:37:58 »
I must agree. Lots of switches have springs, but they're there just to return the switches to their start positions. In the buckling spring switch, the spring actually throws the contact. It's such a fundamental difference, you'll never find anything else like it.
Re: Keyboard feel
« Reply #4 on: Wed, 03 January 2018, 00:23:52 »
I'd say a Model M :p
You can still get them, sometimes even new ones ("new old stock").  For the most part they still work very well.  The switch mechanism lasts for decades.
The biggest issue is plastic rivets falling off - the solution to that is to do a bolt mod - replace the rivets with small bolts and the keyboard is like new again.
Many of them are quite dirty, evidence of a busy life.  They almost always clean up very well if soaked in warm water with a little detergent or denture tabs.
Hence there is often little reason to find something like a Model M, when you can simply get an original Model M.
