Author Topic: Model M Cleaning - "Tape Trick"  (Read 3071 times)
Offline bachamn
    • Forming the Beast
« on: Thu, 26 October 2017, 14:24:45 »
As I've been looking around the boards regarding cleaning up/modding a Model M, I've seen a particular post referenced in a few places:
https://geekhack.org/index.php?topic=54190.0
However the video in this thread has been removed, and I noticed a few people talking about how "brilliant the tape trick" is.
I was able to deduce it's something to do with taping the hammers together before removing to save time, but was curious if anyone is familiar and could provide some clarification.
Offline E TwentyNine
    • Some of My Keyboards
Re: Model M Cleaning - "Tape Trick"
« Reply #1 on: Thu, 26 October 2017, 14:37:57 »
When you're bolt modding an M, after you've pulled all the keys off and removed all the rivets and are about to pull the backplate off the barrel plate...
You put the assembly face down and remove the backplate and membanes.   With the hammers exposed, you run a long piece of scotch tape along each row and pull out the hammer/spring assemblies all at once per row.  You'll end up with a string of them on the tape.
Makes putting it back together simpler supposedly, but it's pretty quick to put them back in individually anyway.
Offline 0100010
  • Not Sure
« Reply #2 on: Fri, 27 October 2017, 23:01:14 »
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #3 on: Sat, 28 October 2017, 00:07:29 »
+1 Definitely. On point.
« Reply #4 on: Sat, 28 October 2017, 08:10:43 »
Furthermore, when they are separated, you can inspect, clean, and adjust each one. The "tape trick" always seemed pointless to me.
- D Trump 2026-09-28
« Reply #5 on: Sat, 28 October 2017, 08:38:25 »
Not just pointless, but possibly negative.  If a little tape residue ended up on the hammer, after you button everything up it could stick (permanently or intermittently).
Offline bachamn
    • Forming the Beast
« Reply #6 on: Thu, 09 November 2017, 16:07:16 »
Cheers for the replies guys, when I was doing my mod I opened the thing without flipping it over first, so all the hammers fell all over the place anyway  ;D
But yeah I'd have to agree that inspecting and putting them back individually isn't a bad idea, especially if it's the first time it's been taken apart since leaving the factory.
« Last Edit: Thu, 09 November 2017, 16:51:18 by bachamn »
« Reply #7 on: Wed, 03 January 2018, 00:39:36 »
I'm in the middle of a bolt and ANSI mod of my M122.
At the appropriate stage I did consider the tape trick (I have seen that video), but given how awkward I am at things like that, it was easier, if more time-consuming, to remove and replace the paddles one by one.
Well, remove was just a case of turning the keyboard upside down and watching them all fall out.
