Author Topic: Need help building SKFL Alps 75%  (Read 2172 times)
Offline wgfwgf
« on: Fri, 27 October 2017, 02:54:46 »
Hi Geekhack, I'm pretty new to building (never needed to) and geekhack (came here from reddit).
I got my hands on a Toshiba T3100 keyboard yesterday and I need some advice. How can I make it work as a standalone keyboard?
If I understand correctly I can't / shouldn't replace the PCB as the 4-pin layout is not something I can fit onto other generic PCBs. Also the switches are PCB mounted. However, I still need a case and a plate to build in, also some controller (?) or adaptor (?) to make it USB (or PS2).
I love the caps (according to deskthority it's not Alps compatible, so I'm keeping the switches), I love the layout, so I'd like to keep those. I can compromise for a 60% if needed.
Pictures are on https://imgur.com/a/FCtCQ before pulling the caps, after pulling the caps and after the shower. What should I do next?
Thanks a lot for any help.
Offline wgfwgf
Re: Need help building SKFL Alps 75%
« Reply #1 on: Fri, 27 October 2017, 03:18:14 »
I might have found something on http://www.instructables.com/id/Make-Any-Vintage-Keyboard-Work-With-a-Modern-PC/ is this almost exactly my use case?
Offline Magna224
« Reply #2 on: Fri, 27 October 2017, 06:11:32 »
Those caps are beautiful. I love vintage switches. I hope your project turns out. NEC blues are nice too and I've thrown montereys into a M0116. I've never actually used those older ALPS. I bet they're great.
