Author Topic: Drevo Excalibur numpad  (Read 2836 times)
Offline sifr
« on: Tue, 31 October 2017, 08:33:39 »
Hello all,
I have a Drevo Excalibur and i was wandering if I can disable the numpad on the keyboard itself but still have it on my mouse (a G600). This was possible on my old Noppoo (just to let you know what I mean) but couldn't find the same operation on the Drevo.
For now, I'm still using my Noppoo to disable the numpad on the keyboard, then I plug in the Drevo to make it works. Actually, I can unplug my old Noppoo and the "disable numpad on keyboard" is still active, maybe there's something I can do directly on my computer like a script or something else to make it happen without using my old keyboard.
Moreover, I found out that sometimes, when I boot my computer, I just have to plugout plugin my Drevo and the workaround is active. I'm a bit lost and don't really understand what's happening on my Windows.
Do you guys know the name of the workaround I want to do ? Or maybe a existing solution is known ?
Thanks in advance
Offline SamirD
Re: Drevo Excalibur numpad
« Reply #1 on: Tue, 31 October 2017, 14:49:28 »
I somehow remember there's some software I read about on here, but it's been years and I can't exactly recall.
Hopefully someone more knowledgeable will chime in.
