Author Topic: HELP, Keyboard not registering at all  (Read 1491 times)
Offline titaniumsack
« on: Fri, 03 November 2017, 17:34:42 »
i have a custom build with a jm60 and it wont register on any computer with any cable, when plugged in it makes the windows connection noise and lights up and everything, it even lets me change colors and all that but it just wont register anything and im lost, is it bricked> do i have to get a new pcb?
Re: HELP, Keyboard not registering at all
« Reply #1 on: Fri, 03 November 2017, 17:39:32 »
in device manager it shows under USB controllers that it is an unkown USB device and that device descriptor request failed, code 43
Offline SamirD
« Reply #2 on: Sat, 04 November 2017, 11:05:55 »
Sounds like either a driver issue or you've got some programming to do.  Was the controller already programmed to go and plug and play?
