Author Topic: Sizing question for Filco compatible pcb  (Read 2935 times)
Offline ljfkidd
« on: Sat, 04 November 2017, 14:05:16 »
So i'm designing a keyboard pcb that ideally should fit in a space filco case I have laying around.
To be compatible with a standard case, what should these dimensions be?
Thanks in advanced.  :)
Offline TalkingTree
    • My projects
Re: Sizing question for Filco compatible pcb
« Reply #1 on: Sat, 04 November 2017, 14:24:05 »
Please note that all the measurements are in millimeters and from center to center of the switches.
Between Esc and F1: 38.10
Between F keys: 28.45
Between F12 and Print: 23.88
Vertical gap: 28.19
Offline ljfkidd
« Reply #2 on: Sat, 04 November 2017, 14:25:09 »
Vertical gap: 28.19
Thanks alot!
