Author Topic: Ergodox Layout Thread  (Read 3960 times)
Offline _rubik
« on: Fri, 10 November 2017, 13:26:08 »
I'm considering switching up my ergodox layout, but I'm curious to see what you all use. Post your layout or unique layers!
Offline _rubik
Re: Ergodox Layout Thread
« Reply #1 on: Fri, 10 November 2017, 13:37:27 »
Mine. Very close to default with a few macro tweaks and redundancies. I REALLY dislike the macros on this, because if you it essentially toggles shift for you, which causes the second key you press in rapid succession to be shifted also.
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Fri, 10 November 2017, 14:32:28 »
Offline _rubik
« Reply #3 on: Fri, 10 November 2017, 15:04:41 »
https://geekhack.org/index.php?topic=42463
That thread really fizzled over the course of 3 years didn't it.  :( Thanks for pointing that out.
Offline ojrask
  • juuh elikkäs
Current:
Coming up:
IC/GB:
Offline davkol
« Reply #5 on: Fri, 10 November 2017, 16:55:12 »
I've just remembered the other layout thread: Ergodox Layout Compendium
Offline _rubik
« Reply #6 on: Fri, 10 November 2017, 21:15:13 »
It seems like this thread concept gets revisited every few years. Never sticks around for long.
Offline davkol
« Reply #7 on: Sat, 11 November 2017, 06:09:11 »
There was the first thread that I linked and it lasted for a while. The other one had a different purpose:
After discussions with Matt3o and jdeblese, it was decided that it would benefit group buy organisers if we could compile a giant list of Ergodox layouts.
This list can then be plotted to generate the most common keycap configurations.
There may be other threads, but almost immediately abandoned and forgotten.
