Author Topic: Space Invaders Key Caps  (Read 4071 times)
Offline TheInverseKey
  • You can run but you cannot hide!
« on: Thu, 16 November 2017, 13:37:46 »
Hi,
I am looking for keycaps for my new Amiga 2000 since one is missing.  If anyone knows where I could find some that would be a huge saving grace.
Thanks
Re: Space Invaders Key Caps
« Reply #1 on: Fri, 17 November 2017, 21:10:21 »
I always dreamed some 3rd party manufacturer would pick up the baton and start making SI switches again, but it'll never happen. It's so niche people don't know what they are missing.
« Reply #2 on: Sun, 19 November 2017, 19:51:36 »
If someone did start, the Chinese would be quick to copy it and flood the market, then it would be mainstream :p
Offline engicoder
« Reply #3 on: Sun, 19 November 2017, 20:03:51 »
Hi,
Thanks
Which key are you missing? I may have an extra.
