Author Topic: QMK Help!  (Read 2153 times)
Offline R0b
QMK Help!
« on: Fri, 17 November 2017, 02:31:25 »
Just finished building my first mk and I've managed to get everything programmed and operational.
I used kbfirmware.com to set my keymapping but I'd like to make some changes.
It looks like there's an option to upload a current configuration for editing but I can't for the life of me figure out which file I'm supposed to be uploading.
I have the .hex file as well as the qmk.firmware folder.
Re: QMK Help!
« Reply #1 on: Fri, 17 November 2017, 02:35:07 »
you want the .hex, i think
Offline TalkingTree
    • My projects
Re: QMK Help!
« Reply #2 on: Fri, 17 November 2017, 05:18:41 »
Offline R0b
Re: QMK Help!
« Reply #3 on: Fri, 17 November 2017, 19:25:00 »
Just a quick update, I found out that the file you need is actually a .json file that needs to be saved from the website separately from the other files. Sadly I'll have to redo it again, but at least I'll have the file from here on out.
Clack on!
