Author Topic: [IC] A Custom built macro pad (Closed)  (Read 3176 times)
Offline e11i0t23
« on: Fri, 17 November 2017, 09:50:18 »
Hi I am starting to design a macro pad in an ortholinear layout and was wandering if you would be interested in purchasing one in a future group buy and to what sizes?
please submit your interest in this form : https://goo.gl/forms/luLC40qzKBSUdyxX2
Thanks Elliot
p.s:
if you would be willing/interested in helping design the PCB, case or plate (especially PCB design which i have little experience in) please PM me. Thanks.
« Last Edit: Mon, 20 November 2017, 04:59:37 by e11i0t23 »
Offline Atredl
Re: [IC] A Custom built macro pad
« Reply #1 on: Fri, 17 November 2017, 11:26:31 »
I’d be interested in a 6x5 macropad that could be used as a numpad with an extra row on the left side. If it could be made with an Aluminum case that would be great.
Offline e11i0t23
« Reply #2 on: Fri, 17 November 2017, 15:40:52 »
please can you put the size ect into the form using the other box for size
Offline Atredl
« Reply #3 on: Sat, 18 November 2017, 19:29:54 »
Yup already filled out the form
Offline captsis
  • Formerly matt2dlg
« Reply #4 on: Sat, 18 November 2017, 21:51:13 »
filled out the form! Can always use more buttons for things
