Author Topic: Amiga 2000 weird issues  (Read 2129 times)
Offline TheInverseKey
  • You can run but you cannot hide!
« on: Fri, 17 November 2017, 10:39:45 »
Hi,
I have an amiga 2000 with space invaders and when it is plugged into the ps2 port the caps lock light turns on and off but there is no other functions working on the keyboard.
If you have any suggestions this would be greatly appreciated.
Thanks
Offline Tactile
Re: Amiga 2000 weird issues
« Reply #1 on: Fri, 17 November 2017, 10:49:54 »
Is the computer turned off when you plug it in? You can't hot plug PS/2.
REΛLFORCE
« Reply #2 on: Fri, 17 November 2017, 11:04:28 »
The computer was off and even with an active converter to usb I have the same issue.
Offline rich1051414
« Reply #3 on: Fri, 17 November 2017, 11:08:24 »
Check the capacitors on the board. That would be the first thing I would check. You should read very little dc continuity through the cap, if you want to test it, but better to just replace them, especially if you notice they are swollen.
« Reply #4 on: Fri, 17 November 2017, 12:04:23 »
I just went through the whole board and the caps seem fine.  After some digging I found that if the caps lock is bugging out then it means "CAPS LOCK stuck after pressing a few times -> bad data connection to mainboard".  I am guessing that the cable bad?
« Reply #5 on: Fri, 17 November 2017, 20:54:44 »
Eh... Amiga keyboards don't talk the PS/2 protocol. You are not trying to connect it to a PC are you?
« Last Edit: Fri, 17 November 2017, 21:01:21 by Findecanor »
