Author Topic: [IC] What keyboard kits do you want produced?  (Read 8880 times)
Offline e11i0t23
« on: Sun, 19 November 2017, 10:56:45 »
Hi
just wandering which keyboard kits you would like to see in the near future?
please fill out this form: https://goo.gl/forms/sK4PFqMDsUAzC1JW2
« Last Edit: Sun, 19 November 2017, 11:32:47 by e11i0t23 »
Offline TalkingTree
    • My projects
Re: [IC] What keyboard kits do you want produced?
« Reply #1 on: Sun, 19 November 2017, 11:37:10 »
70%.
Offline bluesclera
« Reply #2 on: Sun, 19 November 2017, 11:46:55 »
High profile stainless steel 96%
Offline e11i0t23
« Reply #3 on: Sun, 19 November 2017, 12:29:47 »
At the moment the 60% 96% and tkl are all tied so you may get that but at the moment not sure going to run it until the 20/11/17 4pm GMT
Offline e11i0t23
« Reply #4 on: Sun, 19 November 2017, 12:30:52 »
Also don't think ill do a 60% as there are ICs for quite a few atm
Offline cdn-mini
« Reply #5 on: Sun, 19 November 2017, 12:37:34 »
 :thumb: 2nd - something in steel or brass.
« Last Edit: Sun, 19 November 2017, 12:46:36 by cdn-mini »
Offline xondat
  • i'm not a star
« Reply #6 on: Sun, 19 November 2017, 12:46:28 »
What style? Super open question with no plans? :confused:
Offline e11i0t23
« Reply #7 on: Sun, 19 November 2017, 12:52:15 »
probably a metal case option along with a bent plate option for mx style switches but possibly also alps as you can get hybrid layouts for the pcb and sadly no leds ATM in my plans but i may be able to add them in.  and yes no plans realy at the moment so it is just an open question
Offline mudcakehoney
« Reply #8 on: Sun, 19 November 2017, 13:46:54 »
75% high profile, 8deg
Offline KaosJ
« Reply #9 on: Sun, 19 November 2017, 13:53:14 »
I would like something new.
Even if i like 75-96 keyboards, you should try to do something different.  For example a 96 with the numpad that can be splitted could be a good thing (or even alphas splitted like the VE.A).
So for example i could use a 75 splitted module, or just use a 96 keyboard or just use 96 reverse keyboard (numpad on left), etc...
I want something new!
Offline oatmicro
« Reply #10 on: Sun, 19 November 2017, 14:01:29 »
Classic TKL
very clean and simple one
Offline avid
« Reply #11 on: Sun, 19 November 2017, 14:03:56 »
A high quality split board. Simular to VE.A but without the left row. Probably TKL style.
« Last Edit: Sun, 19 November 2017, 14:08:31 by avid »
Offline KaosJ
« Reply #12 on: Sun, 19 November 2017, 14:12:14 »
This ;)
And add a separate numpad with the same design that could match it
Offline t8c
« Reply #13 on: Sun, 19 November 2017, 14:20:21 »
This ;)
yes but left row for macros and artisans.
Offline e11i0t23
« Reply #14 on: Sun, 19 November 2017, 14:23:42 »
so a 96% with a detachable numpad that you can use on both sides with some sort of connecting mechanism like https://www.scan.co.uk/images/products/super/2884819-l-d.jpg with the magnetic connectors?
Offline bluesclera
« Reply #15 on: Sun, 19 November 2017, 14:24:56 »
OH GOD, that sounds absolutely terrible.
Offline Owl-
« Reply #16 on: Sun, 19 November 2017, 14:35:27 »
100% agree. I had a look at the ROG Claymore few months back, I can say the magnetic Numpad is flimsy as fuk.
Split-space kit please! *hint*clueboard*hint*
« Last Edit: Sun, 19 November 2017, 14:38:18 by Owl- »
Offline cdn-mini
« Reply #17 on: Sun, 19 November 2017, 14:50:52 »
detachable numpad????? wtf? i'm out.
Offline Darknight00z
« Reply #18 on: Sun, 19 November 2017, 14:52:36 »
I'm very interested in the data collected on this poll. Could you make the data public when you get enough participants? Would be nice to know what layout people like at the moment.
Offline KaosJ
« Reply #19 on: Sun, 19 November 2017, 14:56:45 »
Numpad can be a separate module that you can put near your main keyboard case (it must be only the same design of the keyboard)
What is bad with detachable numpad for you, just don't buy the numpad if you don't need that part
« Last Edit: Sun, 19 November 2017, 14:58:53 by KaosJ »
Offline Wolf123rt
« Reply #20 on: Sun, 19 November 2017, 15:20:31 »
A TKL with Alps support would be nice
Offline e11i0t23
« Reply #21 on: Sun, 19 November 2017, 15:47:55 »
At them moment i am at 80 people but having it up for another 16 hours so will hopefully get over 100 submissions and then i should be able to share but a number of people for 60% atm
Offline Marutks
« Reply #22 on: Sun, 19 November 2017, 15:52:40 »
65%
Offline amnesia0287
  • Formerly Amnesia
« Reply #23 on: Sun, 19 November 2017, 18:59:20 »
Offline bminhz
« Reply #24 on: Sun, 19 November 2017, 19:08:11 »
I don't know...anything from 65% to higher  :confused:
« Reply #25 on: Sun, 19 November 2017, 23:05:17 »
Like a "MS Natural" tented keyboard but TKL and mechanical.
Offline Ponkan
« Reply #26 on: Mon, 20 November 2017, 13:29:13 »
I want to win my first wkl TKL.
Offline e11i0t23
« Reply #27 on: Mon, 20 November 2017, 13:47:18 »
Wow you guys like a huge range of boards i think we are up to around 25 different requests
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #28 on: Mon, 20 November 2017, 21:09:14 »
Do like the Lyn Ex but with the numpad on the left.
edit+ALPS
