Author Topic: [IC]GMK Camping (GB live!)  (Read 289893 times)
Offline _rubik
Re: [IC]GMK Camping
« Reply #100 on: Tue, 21 November 2017, 21:12:45 »
I agree with that opinion of the green spacebars, spacebar kit definitely needs to be updated.
Besides this, removing the R3 ctrl sounds doable to me. A quick question to HHKB users tho, do you really need a R3 ctrl?
tbh, I don't think I wanna sacrifice any individual novelty key, neither does Monkey six.
I guess we need to start a poll...if I figure out how to start one.. ;D
Sorry guys if I don't quote all of your useful suggetions in my reply..
It's just multi-quote is a headache here...especially to someone who doesn't post a lot.
Do.... NOT.... remove R3 control. It's not HHKB specific either. Let the record stand, I'm totally out of this GB is R3 ctrl goes.  >:D
Edit: IDC about stepped R3 control. That can go for all I care. But standard R3 ctrl is a must.
« Last Edit: Tue, 21 November 2017, 21:14:29 by _rubik »
Re: [IC]GMK Camping
« Reply #101 on: Tue, 21 November 2017, 21:58:49 »
r3 control is probably staying
i think you guys are throwing your own personal feelings into this a bit too much
Offline bminhz
Re: [IC]GMK Camping
« Reply #102 on: Tue, 21 November 2017, 22:20:42 »
Any chance we can get the red space bars instead of green ones? Wouldn't the idea of the additional space bar kits is to have alternatives color different than the mods? Which in this case is green?
Offline kingnestea
Re: [IC]GMK Camping
« Reply #103 on: Tue, 21 November 2017, 23:36:33 »
This is what I'm thinking of
Offline ctrl
Re: [IC]GMK Camping
« Reply #104 on: Wed, 22 November 2017, 01:32:45 »
Suggestions:
Keep the LED windowed keys.
Keep the maroon novelty arrows.
Drop the stepped Control key.
Drop the green novelty arrows.
Add 2 x R4 1.5u Meta keys or novelty keys? This would add HHKB-style support with the outer bottom row keys being 1u Alt keys. It's something I found lacking in the original keyset.
Just my two cents.
Offline Johnee
Re: [IC]GMK Camping
« Reply #105 on: Wed, 22 November 2017, 01:36:57 »
Suggestions:
Just my two cents.
+1 on this. With the addition of moving the 6U spacebars to the spacebars kits.
Offline tectonicplate
Re: [IC]GMK Camping
« Reply #106 on: Wed, 22 November 2017, 08:11:16 »
…Removing multiples of keys with custom novelties on them won't significantly lower the price of the set.
Both color ways of novelty arrows would be preferred… they are a part of this set that stand out. One of my biggest issues with GMK is the general lack of options in design. I'm more or less done buying GMK unless these kinds of options are available. Many of the default GMK legends are not well designed, a lot of sloppy choices were made way back—the draw and appeal to me is the nostalgia—but I'd like to see more variety and have options long-term. A few bucks more isn't an issue if that's the case. We're already spending a good chunk of change here… I need reasons to choose this over so many other things out there.
Offline boxfrommoon
Re: [IC]GMK Camping
« Reply #107 on: Wed, 22 November 2017, 08:54:21 »
I really like this one! Been looking for the SA set for a while but it looks like this color scheme and novelties look great on GMK also!
My only concern is that the muted green ends up being more saturated than in those nice renders. This has happened before e.g. gmk plum and gmk nautilus. I would be all over this set if it would be 100% certain that end product would look exactly like those renders.
Offline iHateKnives
    • Old photography site
Re: [IC]GMK Camping
« Reply #108 on: Wed, 22 November 2017, 11:24:14 »
Have you tried looking at these through an IPS display* :O. I thought Plum came out perfectly. There's only a handful of photos that perfectly capture the colors. It's probably the most difficult set to photograph (tbf almost all keysets that have non-muted colors are hard to photograph, haha).
Nautilus concerns me though cos the yellow from the renders is brighter than the yellow in Zambumon's pictures. But eh, it could just be the filters he added to his instagram photos.
*It won't be 100% faithful to whatever was rendered but it'll be close enough.
**I didn't buy either of the GMK sets you mentioned and I am very, very sad
Edit: The SA Camping photos here have greens that are more saturated than the renders. I get what you mean :). It suddenly looks a bit tacky if the greens aren't muted
« Last Edit: Wed, 22 November 2017, 11:34:43 by iHateKnives »
POK3R 67g Zealios + XDA Canvas + SA Camping
Offline avid
Re: [IC]GMK Camping
« Reply #109 on: Wed, 22 November 2017, 11:56:45 »
Just pick them up on mechmarket. Plum is cheap and nautilus should be plenty available in a few weeks.
Offline wezm
    • WezM.net
Re: [IC]GMK Camping
« Reply #110 on: Wed, 22 November 2017, 19:41:02 »
Re: [IC]GMK Camping
« Reply #111 on: Wed, 22 November 2017, 20:14:39 »
They literally always end up more saturated. It's a symptom of computer monitors. GMK renders are worse than others, but you shouldn't count on them being exact to the renders.
At least in my experience.
Offline amnesia0287
  • Formerly Amnesia
Re: [IC]GMK Camping
« Reply #112 on: Thu, 23 November 2017, 00:45:08 »
Suggestions:
Just my two cents.
I would really like both colors of arrows even if I have to buy the other arrows as a kit lol. But I do think green makes more sense for general use, it fits more readily with 65/75%. I personally do like the maroon though.
The real cost of the arrows is from the molds anyway, it seems like a waste to spend the money for the molds and then only use them once.
I also wouldn't mind 1.5 novelties, could care less about meta keys though.
Offline Kafka
  • i like clean things
Re: [IC]GMK Camping
« Reply #113 on: Thu, 23 November 2017, 11:17:11 »
Add a Watster! Mold is already paid for and Krelbit said anyone can use it :p
Offline avid
Re: [IC]GMK Camping
« Reply #114 on: Thu, 23 November 2017, 11:19:22 »
please dont do this. I think people would much rather have any of the current novelties but in a different color.
Offline bminhz
Re: [IC]GMK Camping
« Reply #115 on: Thu, 23 November 2017, 11:57:36 »
please don't....watster doesn't fit in with camping theme at all! More novelties or more colors would be nice
Offline ctrl
Re: [IC]GMK Camping
« Reply #116 on: Fri, 24 November 2017, 04:48:12 »
Just no.
Offline xondat
  • i'm not a star
Re: [IC]GMK Camping
« Reply #117 on: Fri, 24 November 2017, 05:14:43 »
You've had better ideas :rolleyes:
Offline CandyKeys
  • Just doing EU things.
    • CandyKeys EU MK Store
Re: [IC]GMK Camping
« Reply #118 on: Fri, 24 November 2017, 07:18:12 »
This is exciting stuff! Very hyped to see it at Frankfurt and talk to the host.
This will be great.
The CandyKeys Mechanical Keyboard Store
Offline Kafka
Re: [IC]GMK Camping
« Reply #119 on: Fri, 24 November 2017, 11:47:23 »
:wat:
Offline amnesia0287
  • Formerly Amnesia
Re: [IC]GMK Camping
« Reply #120 on: Fri, 24 November 2017, 12:18:32 »
I’d rather have a watster over a duplicate in a different color. But I’d rather have R2/3 novelties over a watster. But that’s just me.
Offline iHateKnives
Re: [IC]GMK Camping
« Reply #121 on: Fri, 24 November 2017, 12:24:53 »
I think we should also have some sort of discussion as to pricing. I'm willing to pay 160usd just for the base set since this is one of the greats, imo
Offline kingnestea
Re: [IC]GMK Camping (24/11/2017 Updated google form for poll)
« Reply #122 on: Fri, 24 November 2017, 12:29:57 »
Hi guys,
I hope you have a great thanksgiving and got some awesome stuff with the black friday sales.
I've made a Google form to collect votes for the keys that I'm considering to remove so that we can bring down the pricing of GMK Camping a little bit.
Please vote, I will be really appreciated!
https://goo.gl/forms/MyXc3IQdSjFgzErH3
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #123 on: Fri, 24 November 2017, 12:35:20 »
i don't give a sh*t, i'll pay $180 to have them all  :thumb:
Offline bthezebra
« Reply #124 on: Fri, 24 November 2017, 12:37:37 »
Submitted my opinion :)
Sent from my SM-G900V using Tapatalk
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #125 on: Fri, 24 November 2017, 13:16:35 »
My take:
- remove R4 pipe (ISO)
- remove either green or maroon novelty arrows (poll people for this)
- change cardinal direction (text) or arrow icon only (it's too cluttered to have both, from my experience with SA Camping)
- keep both regular and stepped R3 Control
- move 6u spacebars to spacebar kit
- reduce number of R1 1u novelties
- add R4 1u End key
« Last Edit: Fri, 24 November 2017, 13:18:15 by LightningXI »
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #126 on: Fri, 24 November 2017, 17:08:07 »
Filled the form. The “hell yeah, shut up and take my money” is exactly how I feel
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #127 on: Fri, 24 November 2017, 18:34:36 »
My personal opinions on what should be done to the kit:
 - Drop homing scoops and keep the bars
 - ditch the alpha colored F5-F8
 - drop R3 control keys since they don't functionally contribute to the kit, only aesthetically
 - change the R3 iso \| key to have the ~# as main legends since that seems to be what most iso layouts have there
 - keep the R4 \| key since that's crucial for physical iso support, otherwise iso users are missing a key there
 - move 6u spacebars to the spacebar kit
 - maybe add a R4 End, but I don't see that as crucial since there's plenty of R4 1u keys to go there
 - consider slimming down the unique novelty designs, not the campfire though since I dig that
Offline avid
« Reply #128 on: Fri, 24 November 2017, 19:12:45 »
To keep ISO working, the 4 keys are a necessity, cant remove any of the four keys.
Offline Kafka
« Reply #129 on: Fri, 24 November 2017, 19:53:40 »
I really hope you don't consider removing the scoops for homing, almost every recent set has both..
Offline j2c8w6f8
« Reply #130 on: Sat, 25 November 2017, 01:13:43 »
Monkey six god!
Offline zimo
« Reply #131 on: Sat, 25 November 2017, 01:14:41 »
Monkey six god!
Offline iHateKnives
« Reply #132 on: Sat, 25 November 2017, 02:43:45 »
Around how much would the spacebar kit cost? :)
Offline kingnestea
« Reply #133 on: Sat, 25 November 2017, 03:05:04 »
I don't know that yet, because the spacebar kit is not sent to GMK for quote yet.
I'm thinking of changing the green spacebars to maroon, and put 6u there
Offline iHateKnives
« Reply #134 on: Sat, 25 November 2017, 04:43:43 »
Looking forward to those changes. Thank You!
Offline heliar_mk
« Reply #135 on: Sat, 25 November 2017, 06:13:33 »
Does the main kit suit for planck?
If not, what is the R4C 2U space which in spaces kit for?
Offline lithopedion
« Reply #136 on: Sat, 25 November 2017, 10:14:42 »
Pleeeeeeeeease keep the green novelty arrows!
The maroon arrows really doesn't look good on 65/75% keyboards.
Or no novelty arrows at all, so that it can be cheaper.
But as you've said, these novelty arrows are part of what make Camping “Camping”.
As much as you don't want to do it, I still think a separate novelty set would be the best option.
And if possible, please consider changing at least 2 novelty keys from R1 to R2 and R3.
Thanks for making GMK Camping happen!
Offline bminhz
« Reply #137 on: Sat, 25 November 2017, 11:59:08 »
Completely agree with this changes  :thumb:
Offline kingnestea
Re: [IC]GMK Camping (26/11/2017 Kit design revised)
« Reply #138 on: Sun, 26 November 2017, 16:25:03 »
26/11/2017 Rev. 2:
Please see OP for kit renders
Removed:
- R1 1u creamy white F5-F8
- R1 1u green ~`
- R2 1.5u green |\
- R3 1.75u stepped Control, regular caps lock(windowed)
- R3 1u dished F, J, 5
- R4 1u 00
- 6u Spacebars
Added:
- R4 1u End
- R1 1u Green watster novelty key
- R4 2u shift
Changed:
- R3 1u iso key changed to primary legend
- Green spacebars in the spacebar kit changed to maroon
Pls tell me what you think  :)
« Last Edit: Sun, 26 November 2017, 23:24:23 by kingnestea »
Offline xondat
  • i'm not a star
« Reply #139 on: Sun, 26 November 2017, 16:26:11 »
Please keep scooped F/J.
Offline Parva Ovis
« Reply #140 on: Sun, 26 November 2017, 16:28:01 »
Same, scooped F/J/5 can't possibly be that costly to keep.
Offline kingnestea
« Reply #141 on: Sun, 26 November 2017, 16:35:48 »
I'm all over scooped F/J tbh, but surprisingly a lot ppl voted those to go.
I'll see where we are when I receive the quote for this revision. Might be adding those back in the next revision.
In the meanwhile, the poll stays active.
Offline avid
« Reply #142 on: Sun, 26 November 2017, 16:48:37 »
Yes, please get the scooped keys. I have never seen a GMK set without both options and it will only be 1-2 dollar difference.
The novelties in this set is so nice and then a watser is added. Wouldn't it make more sense to add one of excisting novelties in maroon color instead?
With the added scooped i think its excellent.
Offline bthezebra
« Reply #143 on: Sun, 26 November 2017, 16:56:53 »
Definitely keep dished F and J, I recently converted and like them much more than barred.
Offline MeloDet
« Reply #144 on: Sun, 26 November 2017, 16:58:17 »
Looks good! None of the dropped keys really bug me (aside from scooped FJ to an extent), but either way I can definitely live with all of the changes.
Offline Kafka
« Reply #145 on: Sun, 26 November 2017, 17:22:44 »
haha I called the Watster! but pls keep the scooped homing
Offline bminhz
« Reply #146 on: Sun, 26 November 2017, 17:24:36 »
Would love an existing novelty in different color than waster. It ruins the whole set imo...
Sent from my iPad using Tapatalk Pro
« Reply #147 on: Sun, 26 November 2017, 17:45:22 »
Yeah don’t understand the watster.. it’s not camping related and the legend is thin, whereas the rest of the novelties are bold rounded thick lines. It doesn’t match at all
Offline fishpod
« Reply #148 on: Sun, 26 November 2017, 18:07:45 »
Although I love watster, I dont think it fits camping.
Offline BlackInk
    • TeamGSB
« Reply #149 on: Sun, 26 November 2017, 18:15:01 »
Wow can you please add back the 1.5u green |\ i really need that key
