Author Topic: Do you want to see split space bar compatibility on a TKL board?  (Read 7400 times)
Offline e11i0t23
« on: Mon, 20 November 2017, 04:23:17 »
Hi all,
I am currently starting to design a TKL pcb and was wandering do you want to see the option for split space bars on this board as well as a full space bar or not?  Please submit your answer through this from: https://goo.gl/forms/4CaS7NBImq3V8ZNt2
Elliot (e11i0t23)
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Do you want to see split space bar compatibility on a TKL board?
« Reply #1 on: Mon, 20 November 2017, 10:05:23 »
Hi all,
Elliot (e11i0t23)
Why bother asking if people want it, just add it into the design. Doesnt take away from the board as far as i know, but just adds more options.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #2 on: Mon, 20 November 2017, 10:06:53 »
wow dudesnail r u ok
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #3 on: Mon, 20 November 2017, 11:08:49 »
dude, he's dead insisde. Would you be ok?
haha just kidding
Offline baxxt14
« Reply #4 on: Mon, 20 November 2017, 11:20:21 »
How many TKL cases are out there? I haven't seen many around. Or are you going to design one?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #5 on: Mon, 20 November 2017, 11:23:25 »
Offline dubious
  • 쏘쿨
« Reply #6 on: Mon, 20 November 2017, 12:43:48 »
( ͡° ͜ʖ ͡°)( ͡° ͜ʖ ͡°)( ͡° ͜ʖ ͡°)( ͡° ͜ʖ ͡°)( ͡° ͜ʖ ͡°)
« Reply #7 on: Mon, 20 November 2017, 15:45:41 »
no, i do not want split spacebar on a TKL
« Reply #8 on: Tue, 21 November 2017, 00:56:05 »
The real answer is a question: Why not?
BTW. Kbdfans split the spacebar in its DZ60.
« Reply #9 on: Tue, 21 November 2017, 01:00:14 »
swiss cheese 60
not that it's a not a good PCB (it's a very good PCB) but MAN is it a busy looking one
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #10 on: Tue, 21 November 2017, 01:41:19 »
TKL don't need that kind of split. (that's ok for 60%)
this is what I have in mind, though:
182540-0
« Reply #11 on: Tue, 21 November 2017, 01:49:25 »
that's an abomination
but also i am intrigued
Offline Shenpai
  • always found
    • padoru
« Reply #12 on: Tue, 21 November 2017, 09:46:16 »
Sure why not.
Nunu | KR FC660C
Offline DMacKB
« Reply #13 on: Mon, 16 July 2018, 02:04:51 »
I have a quickfire tk and I’ve  grown fond of the case since i sprayed it a beige plastic finish. I want to replace the pcb though so i can have split space and qmk. 6.5U of mostly unused  realestate right there at home position! It’s like a single story house sitting on 2 acres of lawn in the inner city, and I’m a filthy developer.
For my purposes a tkl needs a  numpad option too,cos I can have the arrows or numpad as the need arises and toggle it via qmk tricks.
