Author Topic: Decent caps for fullsize  (Read 3344 times)
Offline PyroL
« on: Mon, 20 November 2017, 17:09:10 »
This is my first post here, so sorry for any mistakes.
I won a WASD v2 with 65g Zealios at the Norcal meetup, it came capless. To avoid this turning into a very expensive gift, what keycaps, under $50 probably, would be good on a fullsize. I like cylindrical GMK/OEM/Cherry caps on anything >75%, but anything is welcome. I'm thinking Originative Carbon OEM, or Gateron Blanks.
Re: Decent caps for fullsize
« Reply #1 on: Mon, 20 November 2017, 22:06:50 »
Offline kokokoy
« Reply #2 on: Mon, 20 November 2017, 23:53:23 »
You may also want to check if Shadovved has any more extra. He was doing some clearance sale on his previous GB
https://geekhack.org/index.php?topic=78563.msg2513940#msg2513940
Offline Mazian
« Reply #3 on: Fri, 24 November 2017, 15:01:45 »
If you had customization in mind, there's always WASD's own keycap set, OEM profile, at exactly $50.
http://www.wasdkeyboards.com/index.php/products/keycap-set/104-key-cherry-mx-keycap-set.html
Offline Badwrench
  • ummmm.....I forgot
