Author Topic: [IC] EP-TKL with first rendor and layout options and more split keys  (Read 5597 times)
Offline e11i0t23
Hi all
I have started designing a new TKL board with split space bar compatibility see image below and want to check your interest in this before i order the prototype PCBs please show your interest in the form --->>> https://goo.gl/forms/oZyIEbA2LK0sv4wh2
This boards features:
  • TKL layout
  • ANSI and ISO comparability
  • Compatibility for split space bar sor single 6.25u, 7u or 10u space bar
  • Alps and MX switch compatibility
  • Compatibility for split backspace key
  • Compatibility for split right shift
please see the first render of the PCB below
182555-0
the layout
and finaly if anyone wants to help support the project please pm me with what you have to offer and what you want in return
thanks
Elliot
« Last Edit: Fri, 24 November 2017, 11:06:09 by e11i0t23 »
Offline Wolf123rt
Re: [IC] EP-TKL with first rendor
« Reply #1 on: Tue, 21 November 2017, 11:18:34 »
No Alps/Matias support?
Offline e11i0t23
« Reply #2 on: Tue, 21 November 2017, 11:19:46 »
switch footprints are alps compatible sorry i forgot to put that in the features
Offline Wolf123rt
« Reply #3 on: Tue, 21 November 2017, 11:36:44 »
Ok cool, I'm interested.
Offline oatmicro
Re: [IC] EP-TKL New Ten-Key less with first rendor and layoyut options
« Reply #4 on: Tue, 21 November 2017, 13:56:40 »
Nice, looking for the case design  :thumb:
Offline TheMissingPiece
  • TheAverageOne
« Reply #5 on: Tue, 21 November 2017, 15:45:02 »
For the sake of compatibility I might suggest a 2.75/1.25/2.25 or 2.25/1.25/2.75 as seen on boards like the M65-A and DZ60. Adding a split right shift option could also help (splitting the shift would allow the unused 2.75u key to be used as one of the spacebars, and many keysets already offer a second 2.25u shift for clueboard/fc660 compatibility).
« Reply #6 on: Tue, 21 November 2017, 17:41:48 »
please make sure it is TX87 compatible
