Author Topic: Need a few blank black keycaps  (Read 2992 times)
Offline QuantumBit
« on: Sun, 26 November 2017, 10:11:10 »
I'm about to get my first mechanical keyboard (Drevo Gramr in white w/ blue switches) and to match my build I want to replace the "WASD" with black blank keycaps. I wanted to use the ones from WASDkeyboards, which are the only place I can find them, but I've heard they're pretty flimsy and bad.. Please don't send entire sets, since I only need 4.
Offline divito
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline Mazian
Re: Need a few blank black keycaps
« Reply #2 on: Mon, 27 November 2017, 13:47:44 »
The Drevo's standard keycaps are thin ABS, so unless you dislike typing on the existing caps for some reason, might as well go with your first thought - the caps will be about the same.
