Author Topic: [IC] 60% case w/ brass plate [under glow][Non-floating 7 deg] Group Buy launched  (Read 57972 times)
Offline sennin32
    • Doyu Studio
Re: [IC] 60% case w/ brass plate under glow Non-floating 7 deg update Jan 31 '18
« Reply #100 on: Thu, 01 February 2018, 08:11:36 »
Hi,
We've got quotation.
And price of group buy will around :
Anodized aluminum : $150
Painted white aluminum : $160
Brass : $250
HHKB and universal usb port (Type-C port as default)has extra cost due to quantity.
Wait...do you mean a BRASS HHKB Case is possible? That is so cool if so!!
Could everything Brass be PVD Coated to avoid tarnishing? Clear coats don’t last too long apparently.
If you didn't crack it, PVD coating will stay pretty long.
This is just a bit shocking. You’re awesome. Full PVD coated brass HHKB keyboard case is gonna be amazing. I’m in.
No option for full PVD coated brass bottom, right?
Any confirmation on the colors for anode?
No, that will be too expensive :(
Should offer black, gray, dark purple and rose gold.
Awaiting confirm color reference.
Offline Vigrith
« Reply #101 on: Thu, 01 February 2018, 08:21:07 »
Hi,
Brass : $250
Really good prices, especially for the powdercoat white - any estimation on the price for HHKB with Type-C?
Offline LightningXI
  • PPD
    • ArtisanMacro
Hi,
Brass : $250
Seems like the white is painted, not powder coated
Sent from my mobile using Tapatalk
Offline Unforgivable
« Reply #103 on: Thu, 01 February 2018, 08:28:06 »
Hi,
Brass : $250
Understood, thank you!
The plate will only work with plate mount Stabilizers, correct? :(
It would’ve been nice if it could use PCB mounted stabilizers, but for the price I can’t conplain at all. :)
Offline Peppermint216
Hi,
Brass : $250
Any reason not to like plate mount? (Have only ever used PCB mount myself)
Offline Vigrith
Oh good point, I saw white and just assumed powder since that seems to be the most common; thanks for pointing that out.
Offline sennin32
    • Doyu Studio
« Reply #106 on: Thu, 01 February 2018, 08:51:09 »
Hi,
Brass : $250
Cost 10 extra for aluminum ver., 15 extra for brass.
Offline sennin32
    • Doyu Studio
It is powder coated, but not sure paint and powder coated is different in English?
It is just different paint method in Chinese.
But sometimes will emphasize it.
For default layout, plate mount stabs cutout.
I've tried it, also work with pcb stabs, but will be hard to exchange it after finish the keyboard.
For other layout, only PCB mount.
Hi,
Brass : $250
I need to learn how to quote less stuff on mobile...
But anyway, I just hear that plate mount Stabilizers tend to be very loose and rattle due to the extra room/less stability versus PCB mount. Hopefully others may chime in with better explanations. :)
If it remains plate mount only, I’ll have to source some authentic cherry plate mount Stabilizers. :)
Offline Vigrith
« Reply #109 on: Thu, 01 February 2018, 09:24:48 »
Very fair. Thank you. Last question, will we be able to still purchase your PCB together with the case when the GB for it releases or do we need to get them separately? If we can buy them together, would there be a possibility to buy assembly?
Looking forward to this, many HHKB/60% in general buys lately but this is definitely one of the most interesting ones.
Offline MeloDet
Wow. That price is insane. Is that including a plate as well?
« Reply #111 on: Thu, 01 February 2018, 10:13:36 »
I was told the HHKB would only support 6u. :(
I really would’ve liked if it was the 7u version, since there’s no DSA/SA/MT3/Old GMK Cherry profile/OEM Profile 6u spacebars, or one’s that match.
Anyone else agree? :(
« Last Edit: Thu, 01 February 2018, 11:49:36 by Unforgivable »
Offline kiwi99
  • that's a gnarly dookie
« Reply #112 on: Thu, 01 February 2018, 10:44:36 »
I really would’ve liked if it was the 7u version, since there’s no DSA/SA/MT3 6u spacebars. Anyone else agree? :(
6u all the way  :cool: :cool: :cool:
Not enough kits out there supporting it. It’d be nice to have at least 2 options (this and the Tina)
Offline MeloDet
« Reply #113 on: Thu, 01 February 2018, 11:17:48 »
Yeah, that's a little odd. I'd recommend op do a poll since I'm fairly certain the vast majority would prefer 7u/symmetrical/whatever you wanna call it.
Offline Visionaire
Does this pricing include a PCB, or is it just the case + plate?
Offline sennin32
    • Doyu Studio
Not include PCB
Offline p_blaze
Does the PVD brass case look like brass color or will it work like an anodization and be able to recolor the brass?
Offline Visionaire
Not include PCB
Bummer. Ok, I'll jump into the GB for the PCB then.
Offline sennin32
    • Doyu Studio
Yes, but this time will be only one color.
Hey Sen,
Could we get a 7u symmetrical HHKB Top option? :(
Offline sennin32
    • Doyu Studio
Hey Sen,
I think it is hard to offer one more layout.
Manufacturer will ask for minimal quantity :(
Offline sennin32
    • Doyu Studio
We're doing another poll for hhkb layout.
It is about 6u and 7u spacebar version.
https://goo.gl/forms/tpRwrwIZhqTfBTwu2
If you're not looking for hhkb version, ignore it :)
Offline Visionaire
Not include PCB
Ok - this may be a dumb question, but will you sell the PCB as an add on with the kit at the time of case GB, or should we buy the PCB in the current PCB only GB?
Offline lac29
This looks really sexy!
Offline LemonBreezes
I would definitely get this with the split 3u spacebars option in brass! I just ordered a variety of enjoypbt 3u spacebars from Taobao too to check out how they match my current keycap sets.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Interested
Offline nug
Is the link on the shop for the brass kit also a test? It says the GB for the case kit ends around Feb 14...
Offline sennin32
    • Doyu Studio
We're editing it :)
Offline duynguyenle
  • Personal text? What personal text???
We're editing it :)
Will the brass plate and brass weight that comes in the final production version have shiny finish like 1st prototype or sandblasted like the second prototype? Hopefully the first since I prefer the shiny finish (it will be coated with a protective layer right? Raw brass tarnishes easily)
Also is the Feb14th deadline true? Awfully short notice for a case GB!
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline gok_nz
  • Enjoy your PBT
    • Website
We're editing it :)
It will have the shiny PVD like the first prototypes. The 2nd batch of prototypes have a matte finish and are coated so they don't tarnish but I think most prefer the shiny version.
The full brass will also be shiny.
I will leave the GB window question for sennin to answer.
Hey Sennin,
So no 7u for HHKB? Is it possible to at least make a few?
There are more 7u spacebars, less 6u.
(There are no GMK 6u spacebars for old school sets, no 6u DSA spacebars, no MT3 6u Spacebars, no 6u SA Spacebars)
Also just to be 100% sure, the HHKB Case is actually a HHKB body, correct? With blockers?
I would totally buy a 7u PVD coated brass HHKB Case (with 1.5 blockers on the left and right side).
Thank you!
Offline Mousy
  • I <3 tootall
    • IG
Looks so good and if I hadn't just picked up two cases I'd be joining this for sure! Will have to keep an eye out for this case down the line though as I do really like it!
- White Kira 60 | Black Kira 60 | TGR Jane v2? -
Offline gok_nz
  • Enjoy your PBT
    • Website
Obvious solution is to sell the other cases! jk
Unlike kbdfans that stock their products after the GB, doyu studio won't be doing the same.
They may have some extras after the GB is over but may come at a higher price.
Offline Mousy
  • I <3 tootall
    • IG
The two I have coming are ones I've been after for a while so won't be parting that easy ;) I'll bite the aftermarket bullet should the want arrise!
Offline sennin32
    • Doyu Studio
Hey Sennin,
Thank you!
Hi,
Sorry, quantity in the check form is not enough to do that.
Prices will become extreme high :(
Offline rm-rf
any chance of a picture or render of design for the hhkb model?
Offline sennin32
    • Doyu Studio
Rendering :)
Offline midnight2903
Rendering :)
I guess I will wait till the rendering is done before I make my decision. HHKB layout is the only one I'm considering :D
Offline kiwi99
Rendering :)
Render from the GB thread for you guys if you havent seen
Offline gok_nz
  • Enjoy your PBT
    • Website
Rendering :)
It may be sacrilege but a gold HHKB sticker would look so good on that.
Offline sennin32
    • Doyu Studio
A numpad matches this case!
Offline eyedrop
Oh boy...
Will there be a brass version?  Is the GB coming right after this one?   ;D
Offline sennin32
    • Doyu Studio
Oh boy...
no,
we have to sampling this numpad first.
So it might take a little while.
may be late Mar ~ early Apr
