Author Topic: [IC] 60% case w/ brass plate [under glow][Non-floating 7 deg] Group Buy launched  (Read 58700 times)
Offline lunr
Re: [IC] 60% case with brass plate [under glow] [Non-floating] [7 deg]
« Reply #50 on: Fri, 15 December 2017, 22:13:16 »
Definitely interested on the powder coated white!
Offline gutsack
« Reply #51 on: Mon, 18 December 2017, 15:28:53 »
Hello, I am interested, okay, great, byethanks.
Offline sennin32
    • Doyu Studio
« Reply #52 on: Tue, 19 December 2017, 04:13:33 »
best reply ever XD
Offline bluesclera
I have to say the polycarbonate bottom ruins it for me. Looks cheap.
Maybe for the brass version, we get a brass bottom?
Offline Peppermint216
« Reply #54 on: Wed, 20 December 2017, 06:28:41 »
Update :
Kit options will be :
1. Case kit only
2. Case + PCB kit
3. Case + PCB + laser engraved white/black keycap kit for default layout
*optional 1 : 70 pcs Kailh Box / Cherry switches include
*optional 2 : cherry PCB stabilizer/plate stabilizer(default layout only)
From IC form,
We will go ahead with following colors:
1. PVD Brass (With limited quantity only)
2. Anodized Black
3. Anodized Gray
4. Anodized purple
5. Anodized rose gold
*6. Powdercoated white (Never tried, we have to make some sample see if the surface is strong enough)
And we'll provide layouts (All mount plate is PVD brass)
1. ANSI universal
2. Our default layout
3. HHKB
4. Split space bar fit most PCBs
5. ISO universal
*6. universal for ANSI/ISO (Only make it under Moq reached)
Sample looks great, I'm in for one ;D
I hope Aluminium Silver is a colour option as seen in the renders, it's not on the list above?
Offline afrokobe
entered the form for full brass
Offline Liam
Man I need this in Brass so bad :'( Please choose me
IBM Model M - Leopold 750r - Custom Numpad
Offline sennin32
    • Doyu Studio
« Reply #57 on: Thu, 21 December 2017, 22:47:30 »
Update :
1. Case kit only
2. Case + PCB kit
From IC form,
2. Anodized Black
3. Anodized Gray
4. Anodized purple
1. ANSI universal
3. HHKB
5. ISO universal
Sorry,
People chose silver is not much, might not able to offer this color :(
Offline bminhz
Agree that the acrylic or poly bottom would look cheap. I am in for brass bottom or anything tougher  :thumb:
Offline Vadurr
  • Valar Morghulis
Am I the only one that doesn't like the way the weight just screws into the acrylic bottom? It looks and seems like it may feel cheap.
Offline duynguyenle
  • Personal text? What personal text???
That's a part that you never touch or even see during regular operation of the keyboard. How is it gonna feel cheap?
How else do you propose the weight be attached if not with screws? Double-sided tape?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Vadurr
  • Valar Morghulis
I guess as long as the acrylic is thick it should feel sturdy enough.
Offline bluesclera
I worry about how well the screw threads in the plastic will hold up from repeated disassembly and assembly through the years.
It will be the first thing to go imo.
Offline mnmlisme
even without the extra weight plate, it should be pretty sturdy already isn't? brass plate and all.
XD60 (gat.black) | SABER68 (gat.blue) | VORTEX Core (cherry blue) | YD40 (gatistotle)
Offline duynguyenle
The plastic part is not threaded. What's threaded is the brass plate. The plastic bottom merely has holes drilled into it for the screws to go through...
Offline gok_nz
  • Enjoy your PBT
    • Website
This is correct. The threading will always be in the metal, not the plastic. The oversized holes will have countersunk screws to make sure they align correctly except for the brass name plate that relies on 6 screws and the recess for alignment.
Offline sennin32
    • Doyu Studio
There won't have threads in the PC plate.
It has to be a through hole.
Or not able to put the parts together.
And I've tried to make the screw very tight.
and will try it several times more, check if it will crack.
Offline bluesclera
I can pay extra to have it assembled for me?
Offline cdn-mini
The only 60% board i'm ever planning to buy so BRASS BOTTOM option please.
Offline gok_nz
  • Enjoy your PBT
    • Website
But then you would be forfeiting the cool underglow! Are you looking to build it with something like a Zeal60 instead?
Offline Harms
Very nice case and design :)
However, I wish there was an option for a full brass/alu bottom.
For those who do not want/need the underglow.
Offline gok_nz
  • Enjoy your PBT
    • Website
This may be possible but how much would you be willing to pay for something like this? My understanding is that relative cost to machine this would be a bit higher than usual due to the lower quantities.
Offline Harms
Yea true full brass would be pretty pricey :P
Offline RSC
Is this happening?
Offline gok_nz
  • Enjoy your PBT
    • Website
Is this happening?
Sure is. From what I've heard, they are waiting for the next prototype and will do a full build with it to ensure that everything is good.
« Last Edit: Fri, 19 January 2018, 13:30:38 by gok101 »
Offline MassaNor
The design of this case is almost perfect for me.
The bottom of polycarbonate is nice as it looks like an apparel accessory as long as the rendering image is, but I agree the actual appearance will look quite cheap.
I hope that this GB will happen soon.I can't wait!
Offline MxBlue
  • buy my keyboard
How will the weight be fixed? Screw and washer?
Offline duynguyenle
Threaded holes in the brass plate, through-holes in the polycarbonate bottom, and countersunk screws (or pan/caphead screws) most likely!
Offline MxBlue
  • buy my keyboard
Oh yes, that would work indeed.
Offline oommymozg
GB of DO 60 is beginning, but is there still GB of this case?
When is the expected start date and shipping date?
Also, at this moment, can you tell me the plate option that reached MOQ?
Offline sennin32
    • Doyu Studio
The white is made painting now.
But we found another way to make white anodize.
We'll ask for color sample for that.
The other sample is gray one!
Any timeframe for this?
Will the DO60 GB expire before this or will this kit include a DO60?
Offline Hellcatz
count me in for 1
Offline pixelpusher
These look really nice. Great job!
Are there any photos of the board with keycaps installed so we can see how inset they are?
Offline Vigrith
Would like to know too. Also, the white looks lovely.
Offline Unforgivable
This looks great! What will the price be?
Any chance for HHKB tops? I would seriously love one in a Crimson Red. ;)
You will also have plates for 6.25u/7u spacebars, right?
« Last Edit: Mon, 29 January 2018, 12:26:13 by Unforgivable »
Offline azulyf
I have asked the same question on reddit. The OP told me that GB for the kit would run sometime later than the PCB. PCBs are going to be restocked then, and everyone joined in PCB's GB now would get a discount in the kit GB.
Offline gok_nz
  • Enjoy your PBT
    • Website
If what are you wanting to know is whether there is a visible gap between the walls and the bottom of the keycap, then that's a no. It's a 'true' high profiled board.
Offline pixelpusher
Offline sennin32
    • Doyu Studio
We might go ahead with blockers for HHKB :)
It will start soon, but might after PCB gb ended.
Not sure if we can modify the sample before this week.
Offline Visionaire
Looks really great! I want one.
Offline duynguyenle
Will there be an option for ISO plate too? (or if not, Universal plate is an acceptable substitute in my view)
The PCB already has ISO support so hopefully this is not a big ask!
Great news! If it’s not too expensive I might have to buy one of each!
Any chance you could make a Crimson Red HHKB Top a color option? :(
Will you also have non-split spacebars plates too?
« Last Edit: Tue, 30 January 2018, 21:27:38 by Unforgivable »
Offline bluesclera
No metal bottom i guess?
Offline sennin32
    • Doyu Studio
Re: [IC] 60% case w/ brass plate under glow Non-floating 7 deg update Jan 31 '18
« Reply #94 on: Thu, 01 February 2018, 06:11:08 »
Hi,
We've got quotation.
And price of group buy will around :
Anodized aluminum : $150
Painted white aluminum : $160
Brass : $250
HHKB and universal usb port (Type-C port as default)has extra cost due to quantity.
Offline duynguyenle
« Reply #95 on: Thu, 01 February 2018, 07:28:40 »
Hi,
Brass : $250
Good news! Please don't start the GB until after Chinese New Year if you can! Busy time of year for me  :thumb:
What surface finish will the brass version have? Will it be polished and ptoteched with a clear coat? Raw untreated brass will tarnish very quickly (and also kinda smells unpleasantly metallic)
« Reply #96 on: Thu, 01 February 2018, 07:41:31 »
Hi,
Brass : $250
Wait...do you mean a BRASS HHKB Case is possible? That is so cool if so!!
Could everything Brass be PVD Coated to avoid tarnishing? Clear coats don’t last too long apparently.
Offline sennin32
    • Doyu Studio
« Reply #97 on: Thu, 01 February 2018, 07:46:17 »
Hi,
Brass : $250
If you didn't crack it, PVD coating will stay pretty long.
Offline sennin32
    • Doyu Studio
« Reply #98 on: Thu, 01 February 2018, 07:48:39 »
Hi,
Brass : $250
polished and PVD coating.
We should start before new year vacation.
Cause we want place it ASAP after vacation.
« Reply #99 on: Thu, 01 February 2018, 08:05:15 »
Hi,
Brass : $250
This is just a bit shocking. You’re awesome. Full PVD coated brass HHKB keyboard case is gonna be amazing. I’m in.
No option for full PVD coated brass bottom, right?
Any confirmation on the colors for anode?
